Help ID a sensor?!
Old Feb 25, 2009 | 11:56 PM
Chad83's Avatar
Help ID a sensor?!
Ok I was working on my TPI and found a melted plug with one wire its green with white stripe and the sensor kinda looks like the knock sensor this is located next to the temp sensor they are side by side on the front of the intake manafold ...
Any info is help full ...
Chad
Old Feb 26, 2009 | 12:47 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Help ID a sensor?!
What year? Stock manifold? I don't see anything like that on mine.
Old Feb 26, 2009 | 01:47 AM
Chad83's Avatar
I have no clue on exact yr and I assume its a factory intake...
Ok here are all my casting #
block
GM5.7LG
14016379
L20
A053800
head
3998993
A50
Gm55
The tune port injection
is 90-92 No vats I also have a casting # off the intake 01305
Old Feb 26, 2009 | 03:21 AM
johnny89345's Avatar
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
Chad
can you take a picture idk what it sould be neither of my camaros have that
Old Feb 26, 2009 | 09:15 AM
Chad83's Avatar
Ill post a pic by 8:00pm EST
Old Feb 26, 2009 | 12:26 PM
tinymay's Avatar
Engine: 5.7 TPI
Without a pic... best guess for that location is a Temp sensor which has more than one wire and the oil pressure switch. Does the sensor have a hole in the block end??
EGR diagnostic switches have a green wire but not located at the front like you said. A photo would help a bit.
Old Feb 26, 2009 | 10:06 PM
Chad83's Avatar
Thanks but I have found out that it is a knock sensor plug with a knock sensor on the intake Iguess their is a first for everything.
Old Feb 26, 2009 | 10:43 PM
S105.7's Avatar
Car: '87 S10 Blazer & '91 RS
Engine: L98 & L03
Transmission: 700R4 & T5
Axle/Gears: 10 Bolt/3.73/3.42
Knock sensor should be blue. A green/white wire is more likely to be coolant fan temp switch. They share the same style connector.
Old Feb 26, 2009 | 10:44 PM
driver101's Avatar
Car: 91 rs,1 92 rs,92 b4c/1le
Engine: 5.0tbi,5.7 tune port/5.0tpi
Transmission: 5spdx2 and t56
Axle/Gears: 3.08,3.73,3.42
pressure switch on ac compressor
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
