Please Help!!!
Old Feb 27, 2009 | 07:38 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Please Help!!!
Hi Guys,
I've been struggling to find a vacuum leak for a while now. I've replaced the intake & runner gaskets and the vacuum lines. I've tried unplugging the brake booster hose, unplugging the fuel pressure regulator and the vacuum line next to it. Yet I still have a surge at idle! Last night I readjusted the valves. But still surges. The IAC is new and the throttle body is clean. I've sprayed carb cleaner everywhere but simply can't find it.
If anyone has any ideas, please let me know... I'm running out of ideas
Just wondering... would an exhaust leak cause the engine to surge?
Thanks!
Old Feb 28, 2009 | 10:50 AM
Re: Please Help!!!
anyone?
Old Feb 28, 2009 | 12:18 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Re: Please Help!!!
Do you KNOW you have a vacuum leak? Have you hooked up a vacuum gauge to a port and checked?
Old Feb 28, 2009 | 01:16 PM
tinymay's Avatar
Engine: 5.7 TPI
Re: Please Help!!!
A sticky EGR valve can pass a big part-time leak that's hard to trace.
Another guess would be your new IAC needing a reset to "0" counts, if you have not already done so.
Do you smell a strong gas odor sometimes??
Old Feb 28, 2009 | 01:30 PM
8urv8's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6 w/.425" cam (Int. & Exh.)
Axle/Gears: Stock
Re: Please Help!!!
Have you checked your EGR valve and other emissions related vacuum hook-ups?
Old Feb 28, 2009 | 04:37 PM
Re: Please Help!!!
Thanks for the replies!
The EGR has been deleted (see sig). I don't smell gas. I have reset the base idle on the throttle body but it didn't help. How do you reset the IAC???
Old Mar 1, 2009 | 05:11 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: Please Help!!!
look
https://www.thirdgen.org/tpimod2
Old Mar 1, 2009 | 07:43 AM
Re: Please Help!!!
Originally Posted by jamon8
Thanks, but I already did this.
My motor will idle fine for a little bit then surge ~200rpm... then idle fine, surge etc.
