help i need to get to school tommorow car timing is screwed up
Old Mar 8, 2009 | 04:30 PM
louflemm's Avatar
i have a 1986 trans am ws6 with the lb9. First I was feeling the car was'nt right. So i checked the timing. It was 40 degrees advanced. Next i retarded the timing to like 6 degrees adavnced. It sounded sweet lol. then i took it for a test drive and the car was just screwed up i hooked the wires back up and all. the car was not responding to the gas pedal. wasnt going past 20mph. then my check engine light came on. it felt like i was gonna barely make it home. what is the base timing for the lb9 and after doing that how would i adjust the tps, and air thing w/e its called. please help cause i need to go to school tommorow and i will deffinelty not make it. THANKS!!
Old Mar 8, 2009 | 04:58 PM
Saculia's Avatar
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
Re: help i need to get to school tommorow car timing is screwed up
Base timing is 6* BTDC. You need to adjust the base timing with the EST wire disconnected. This will bypass the electronic spark timing. This is a single wire connector that should be located near the back of the right valve cover. It is tan and black I believe. The base timing should also be located on the label under the hood.
1992 Trans Am
May 10, 2023 07:19 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
camaro71633
Sep 1, 2015 10:24 AM
Exxon Limited
Aug 9, 2015 08:13 PM
