help with 89 tpi
Old Mar 13, 2009 | 07:47 AM
kmino's Avatar
help with 89 tpi
Hello there. I have a 85 el camino with a 1989 350 tpi motor that was installed by someone else. i have noticed that there is no MAF sensor or no MAP sensor?? I thought you needed one of these for engine load? Or is it possible that it is using N alpha fuel injection that is just using the tps and engine speed? Would it be beneficial to install one of these systems? the car seems to run fine,maybe a little rich, the guy has been driving it like this for years? any input would be greatly appreciated. thank you
Old Mar 13, 2009 | 07:51 AM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Re: help with 89 tpi
got any pictures?
Old Mar 13, 2009 | 08:08 AM
kmino's Avatar
No i do not but you would have to trust me it does not have either one of these.
Old Mar 13, 2009 | 09:40 AM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
A stock 89 tpi will run without a maf sensor, but it will be in "limp" mode, a preditermined set of values the ecm will use without a maf and not meant for daily driving.
I do think that there are aftermarket ecm's available that eliminate the maf altogether.
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
