injection issues
Car: IROC Z28
Engine: 5 litre 305
injection issues
does it matter which way round the injector wires go? as mines rough on tick over seems better when swappibg wires around
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Re: injection issues
I would think it does matter, because when the injector recieves the pulse, it opens and fires fuel, if your firing fuel into the wrong cyl, or no fuel is getting into the cyl thats next in order to fire, you can have some issues.
if it is a 3rd gen then the injectors on a tpi are batch fire meaning one side fires at the same time and not sequential injection meaning timing the injector firing to the valve opening...
Car: IROC Z28
Engine: 5 litre 305
ok thanks, its running rough not sure why almost a miss fire, seems to go when reved up, im gonna put new plugs in and some fresh fuel as the cars been off the road a hell of a long time, hopefully that will put it right
what else could it be ive tried leads, cant find an air leak, should be alright its all new gaskets
TheTraut88
Sep 7, 2015 05:22 PM
