Injector size
Old Mar 17, 2009 | 07:58 PM
87transGTA's Avatar
Car: 87 GTA
Engine: 350 Tune port
Transmission: 700r4,2500 stall
Injector size
hey guys i just ordered some new fuel injectors 24lb, is it neccesary to have to do a tune or will the computer just learn it itsself thanks in advance
Old Mar 18, 2009 | 04:34 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: Injector size
Ideally, the computer should be tuned. You are adding fuel, so unless there's additional air to match, it will run rich. You may be able to get by with an adjustable fuel pressure regulator, bumping down the pressure a little.
Old Mar 18, 2009 | 04:37 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Injector size
Supposedly the ECM has enough play in it's own tuning to be able to handle a 10% variance in injector size. You should be fine. But as Ward said, "ideally" you should do it yourself.
Old Mar 19, 2009 | 11:29 AM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
Re: Injector size
24# injectors on stock tune? lol watch my vid....looks like a diesel that modified rolling that much black smoke LOLOL
ive got 24# Lt1 injectors in a base l98 MAP computer...needs tuned bad...
also...dont run a cat running this rich...plugged up one almost instantly on mine lol
http://www.youtube.com/watch?v=PGimL5rA6fc
Old Mar 19, 2009 | 01:42 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Re: Injector size
Actually, the 24 lb injectors will be really close to what you have know. If you are running a 7730 ecm, all you have to do is change the injector flow rate using Tunerpro and a laptop. Total job after once you get all the pieces and parts shoudn't take more than 30 minutes.
Old Mar 19, 2009 | 04:24 PM
87transGTA's Avatar
Car: 87 GTA
Re: Injector size
what all would i need to use the tunerpro cause i just got my hands on a laptop
Old Mar 20, 2009 | 02:17 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Injector size
You need to read the "Introduction to PROM Burning" tech article on this website to do your own programming. Its not as simple as ibmtech makes it out to be, for a newbie.
Hopefully there is someone local to you that can burn chips?
92projectcamaro
Jan 18, 2016 08:00 AM
toronto formula
Nov 10, 2015 06:17 AM
Brother Al
Oct 14, 2015 06:39 AM
knight72
Aug 10, 2015 09:32 PM
