set timing without timing marks
Old Mar 28, 2009 | 04:27 AM
jp sunshine's Avatar
Car: 87 TransAm
Engine: 5.7
Transmission: 700-R4
Axle/Gears: Stock
I recently completed a top end rebuild on my 87 T/A 305/TPI...the intake was leaking so i removed it only to break a bolt in the head. After several failed attempts to remove said bolt I gave up and took off the heads...at this point I decided to throw in new lifters, rods, rockers, etc. Rebuild went fine but I accidentally ran over my timing chain cover with the timing tab on it. (I did this in my driveway and my other car was right next to my T/A.) I replaced it with an aftermarket cover with no tab on it...time was an issue. I figured I could get it pretty close by ear but I've always relied on the timing light so I don't think I did enough of a good job. She runs good but she lacks power when I accelerate. She's also got a decent vibration...almost like a misfire.
Do we have any old school tips to setting the timing without marks or lights?
Old Mar 28, 2009 | 06:51 AM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Re: set timing without timing marks
You could always buy an aftermarket tab.
Old Mar 28, 2009 | 07:43 AM
GICATA's Avatar
Car: '83 WS6 T/A 65,000 miles
Engine: 5.0L vin H stock, 406SBC right now
Axle/Gears: Corp. 3.73
Old gearheads will tell you to keep bumping it up till it pings when driving in high gear, then back it off a couple degrees. Someitmes you can advance the dist till the idle starts to fall off, then back it off a little.
By todays standards I would get a tab or better yet, the stock TC and set it the proper way.
Old Mar 28, 2009 | 10:09 AM
Car: 87 TransAm
Engine: 5.7
Axle/Gears: Stock
You're absolutely right. I'll probably end up making it worse if I keep messing with. I'll hit u pull n pay and find a stock cover.
Thanks guys.
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
