vaccum hose help
Old Mar 28, 2009 | 09:38 AM
Gutz's Avatar
Car: 89 GTA
vaccum hose help
Hi i have an 89 GTA with a L98.I had a intake leak last summer and just got it back together last week-end.I have two questions for you guys.On the passenger side on the rear side of the plenum there are two barbed ends.One bigger and one smaller then the other.Where do these go?Then on the drivers side base manifold in between where the runners seperate there is a big barb that comes out off base manifold.What goes here?I've seen a couple of pics of the pcv valve going to this but my pcv goes to my brake booster.Thanks for your help.
Old Mar 28, 2009 | 09:54 AM
jugheads88gta's Avatar
Car: 89 camaro
Engine: 68-454,87-nothing yet,88gta-305 tpi
Transmission: stock 700r4
Axle/Gears: borg warner 9-bolt/3:27 gears
Re: vaccum hose help
i have the same problem but i cant figure out where any of the vac lines go to
Old Mar 28, 2009 | 10:15 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Bigger of the 2 barbs on the rear is for the brake booster.
The one from the base itself between the runners on the drvr side is for the PCV.
Thats how it is on my 91's which are Speed Density.
I want to say your extra one on the rear is for the vacuum lines for the interior like the flapper ducts for the AC system vents. On a SD car it comes off the right side of my plenum and is located next to the FPR line as well.
Like I said, for you MAF guys I am running on memory.
Hope it helps
Old Mar 28, 2009 | 10:34 AM
Gutz's Avatar
Car: 89 GTA
Thanks for the help, but it must be different between maf and sd.
Old Apr 11, 2009 | 12:37 AM
Car: 89 camaro
okay so i found where all the vac lines go to the larger one one the plenum nearest to the firewall on the pass side goes the the little pump looking thing on the back of the fuel rails and the one right in front of it goes the the bracket the goes under the ign coil i if that helps any.
Old Apr 11, 2009 | 02:07 AM
1989IROC-Z5.7L's Avatar
Car: 1987 Buick WE4 Regal
Engine: 3.8L IC Turbo
Transmission: 200 4R Auto O/D
Axle/Gears: 3.42 posi
This is what I found.
Hope it helps!
Old Apr 11, 2009 | 02:44 AM
Car: 89 camaro
Hope it helps!
yepp thats how i furgured it out its in the repair book almost the same pic
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
2012sergen11
Oct 13, 2015 07:38 PM
st.evel07
Sep 19, 2015 09:24 PM
rjcme
Sep 5, 2015 01:23 PM
