settin the timming.. havin probelms!!
Old Feb 24, 2009 | 06:23 PM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
so i got my motor up and runnin again and i need to get it tunned bad! Today i thought i would check the timmin and make sure its set right. i unplugged the connector that your supost to and hooked up the timmin light. I could not find the mark anywhere. so i took some white-out and taped it to the end of a long flat head to reach down there haha got it nice and white and tryed again but still nothin. i can twist the dist both ways tell the motor dies and still cant find the white line...what gives? No matter if the timmin wire sensor thing is un-plugged or plugged i cant find the white line. what am i doin wrong? thanks guys
Old Feb 24, 2009 | 06:31 PM
kerplunk318's Avatar
Re: settin the timming.. havin probelms!!
Did you successfully get any mark on the damper? try goin from the bottom. Also try gettin the light on the other side and see if you can see the mark. Are you using a trashed damper or is it new? after a while the gm ones spin a little and you can't correctly time the motor.
Old Feb 24, 2009 | 06:33 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Is the timing light hooked up to #1 spark plug wire?
Old Feb 24, 2009 | 06:41 PM
tinymay's Avatar
Engine: 5.7 TPI
Just a thought of what happened to me before... Had two wires crossed.
Check the order 1-8-4-3-6-5-7-2
Other than that, it almost has to be a spun balancer.
Old Feb 25, 2009 | 04:16 PM
Car: 92 1500p\u 2wd
if its a spun balancer is the only way to fix it a new one? ill check the order to make sure the wires are right. i never checked with the light on the bottom but i never could see the mark.
Old Feb 25, 2009 | 04:41 PM
I was saying to mark the balancer from underneath, not aim the timing light down there, sorry for the confusion. and yes you would have to get a new balancer if it spun, Im thinkin you cant see the mark, plug wires are wrong, or you have the light hooked up to the wrong plug wire
Old Apr 6, 2009 | 10:05 PM
Car: 92 1500p\u 2wd
ok so this 1-8-4-3-6-5-7-2...on the motor im guessin it starts from the front of the motor on the driver side "1" then the front of the motor passenger side "8" the back to the driver side "4" and so on right? so how does it go on the top of the dist cover? i want to make sure they are right befor i diside its a spun balancer.....
Also if it is a bad balancer, how bad are they to replace?
Old Apr 7, 2009 | 12:10 AM
Driver's side front to back is 1-3-5-7, passenger side front to back is 2-4-6-8. On the distributor the firing order (18436572) goes around clockwise.
Rotate the motor so that the number one cylinder is at top dead center of the compression stroke. Then pop off the distributor cap and the rotor should be pointing to the spot on the cap where the #1 wire goes. Check each wire moving clockwise around the distributor and follow each wire making sure it goes to the correct cylinder.
Balancers are not hard to replace but you need a special puller.
Old Apr 11, 2009 | 10:21 AM
tinymay's Avatar
Engine: 5.7 TPI
Yep...
To add... you want the compression stroke on #1 cylinder which blows air out the spark plug hole until the timing marks line up. At that point the rotor needs to be pointing at the drivers headlight. If you have those two things, make the rotor\cap line up with wire #1 and continue clockwise on that firing order.
IceBlue91z28
Theoretical and Street Racing
27
Jan 8, 2007 08:03 PM
matts90firebird
Apr 19, 2003 01:56 AM
383 Smoka
20
Dec 19, 2002 05:59 PM
Mark A Shields
Oct 2, 2002 12:36 AM
poorboy8
Mid-Atlantic Region
Aug 20, 2002 08:42 PM
