Odd issues with L98
Old Mar 31, 2009 | 08:55 AM
Kamorov's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: L98 TPI 5.7L
Transmission: Stock ... For now
Axle/Gears: Borg-Warner 9-Bolt
Odd issues with L98
Recently purchases a '89 GTA with a MAF TPI 350. The issue I'm having is that when the right bank injector fuse (F/P Inj 2) is in place the motor will turn over but not run. As soon as I pull that fuse out it will run but obviously only on the left bank injectors. As soon as I plug in the fuse for the right bank the motor dies. With the fuse in (durring cranking) the injectors pulse (using a noid light) and there is appx 39psi fuel pressure at the schrader valve on the right bank fuel rail. Plugs, wires, and coil have been replaced and the cap and rotor are in good working condition. On a whim I check the fuse cradle for Inj 2 and both sides are showing appx 13v. When the fuse is in it a ts as if it's getting no fuel as I sprayed injector fluid in the intake and it ran ...
Old Mar 31, 2009 | 02:48 PM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
Re: Odd issues with L98
you have a shorted injector or injectors on that bank, 89 uses junk multec injectors that like to short out. you can measure the resistance across each injector to see which ones are shorted. they should read ~12.5 to 16 ohms, any thin below that is bad.
Old Apr 1, 2009 | 09:04 PM
Kamorov's Avatar
That was it many thanks ... Any reccomended replacements??
Old Apr 1, 2009 | 09:31 PM
southbay08's Avatar
If you are looking for injectors 22lb Bosch design lll's are the way to go, no modifications necessary. If you are interested in purchasing a set, you will save 10% on any set of injectors or clean/flow service with our special. Go to www.southbayfuelinjectors.com
type in discount code: TG11 at checkout and you will save 10%
Old May 16, 2009 | 03:03 AM
Chilekesh's Avatar
Car: '89 Trans Am GTA
Engine: L98 - 350 TPI
Axle/Gears: 3.27 BW 9 Bolt
That's interesting. My engine is '89 L98 350. All of my stock (I believe) injectors read 17.5-17.6 ohms. Does that mean they've been replaced before? Their flow is supposed to be 22lb/hr right?
lt500r55
Sep 1, 2021 01:30 PM
NBrehm
Aug 25, 2015 11:49 PM
TheExaminer
Aug 19, 2015 10:07 PM
NufNuffZ28
Aug 14, 2015 09:12 AM
matthew911
Aug 12, 2015 09:38 AM
