TPS connector maybe broken??
Old Apr 1, 2009 | 04:52 AM
camaro87-alex's Avatar
Car: 1987 Chevrolet Camaro SC
I think my tps connector is bad...
I have had a lot of idle problems on my 87 TPI Camaro..305 Engine..
Today I was going to check the TPS voltage. It is a brand new TPS sensor.
I put a jumper fire from the terminal in the middle and measure with voltmeter between that one and ground..I got around 0.54 to 0.56 volts..
If I just touch the tps sensor wiring harness a little bit with my finger the volt goes up to 4.5volts...and then I mean just a little bit with my finger...I guess this is affecting my driving because when engine runs and car shakes from driving it would affect the volts??..
Don't you think I should replace the connector??..
Old May 6, 2009 | 06:02 AM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Re: TPS connector mayby broken??
Going to chime in on this one, should be good
Old May 6, 2009 | 04:27 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
yep I would replace the connector. The voltage should not hop around when you touch the plug.
Old May 7, 2009 | 03:26 AM
I have tried to change the TPS switch and that worked out okay...The TPS switch was new but somehow I have manage to destroy the metal pins inside the TPS so I guess they were touching (short ground) each other..
My car works better now and I have about 0.56 volts on the TPS at IDLE..
BumpaD82
Feb 26, 2016 02:57 PM
skeltor
Feb 2, 2016 10:37 AM
Chevy86 IROC-Z
Sep 7, 2015 01:13 AM
middian
Sep 5, 2015 01:42 AM
