Vacuum lines
Old Apr 2, 2009 | 02:50 PM
PURPLEFORMULA's Avatar
Car: '89 Formula Firebird
Engine: LSX-451 / 705HP
Axle/Gears: Moser Ford 9" with 4.30
Vacuum lines
Where can I get replacement hard vacuum lines for a TPI?
Old Apr 4, 2009 | 01:43 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Re: Vacuum lines
You can't. They just don't make them anymore. Your options are finding good used ones in a junkyard (good luck with that too by the way), or making new ones from rubber vaccum line available at the local parts store. The factory lines looked nice and neat, but they just didn't last forever.
Old Apr 4, 2009 | 04:19 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Vacuum lines
If you mean the small ones (1/8 and 3/16) hard plastic ones, Advance and most other parts stores have them. They are usually in a blister pack rolled up. They are tough to get straight again though. Use a hair dryer or other heat source.
Old Apr 6, 2009 | 09:07 PM
bowtie1983ss's Avatar
Engine: 5.7 Liter Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: 2.77:1 Borg Warner (Stock)
Re: Vacuum lines
TPI Parts has some lines, but not all. www.tpiparts.net
gta892000
Aug 11, 2019 11:16 AM
camarohelp
Sep 12, 2015 05:45 PM
Doobie52
Sep 11, 2015 06:19 PM
IROCtometal
Sep 9, 2015 10:01 AM
snakeshooter
Sep 7, 2015 11:13 AM
