NEED HELP IMMIDENTLY! CAR WONT START!
Old Apr 5, 2009 | 03:09 PM
CarterCarbureto's Avatar
Car: 1987 Z28 camaro
Engine: 305 V8
Transmission: auto
Axle/Gears: 10 bolt pozi
Yet another one of these threads.
Okay here's whats happening, When I turn the key the car cranks, but only the cold start fires. And the car will not turn over.
I can force the car to turn over by giving it a shot of intake cleaner into the TB, and the car will then start and run just fine. Until you shut it off. Then once its warm nothing will fire.
Things ive done:
-Replaced the fuel pump relay
-Replaced the ignition control module
-Replaced the Distributor cap and router
-Fuel Filter
Ive tested;
The injectors, there all getting the single
Fuel pressure, its consistent between 38-41 PSI
Got spark
Plugs are not fouled
I put another 1987 TPI 305 ECM and prom in it, no change
Help! im pulling my hair out over this >_<
Old Apr 5, 2009 | 06:03 PM
Engine: 305 V8
Transmission: auto
Re: NEED HELP IMMIDENTLY! CAR WONT START!
unplugged the TPS and the car starts. Im gunna replace that sensor
Old Apr 5, 2009 | 06:55 PM
Engine: 305 V8
Transmission: auto
Car seems to work now
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
