Is the flow booster worth it?
Old Apr 7, 2009 | 05:40 PM
Lunchb0x8675309's Avatar
Car: 1988 Iroc-Z28
Is this worth it?
http://www.slponline.com/view_product.asp?P=22100
"SLP TPI throttle body flow booster cleans up air flow entering TPI engine throttle body. Made from high-grade cast aluminum, and will increase throttle body air flow by 30 cfm. Includes installation hardware and instructions."
And does it indeed go right in with no other modifications to the intake?? Also sorry if this makes me seem like a noob, but what is the difference/purpose of a throttle body spacer over this? Thanks
Old Apr 8, 2009 | 12:16 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: Is the flow booster worth it?
This is just an air foil. Do a quick search... this has been discussed many times.
Old Apr 8, 2009 | 12:19 PM
Car: 1988 Iroc-Z28
I did do a quick search though I didn't come up with anything. Thanks for the response though.
Old Apr 8, 2009 | 12:31 PM
No problem.
Try searching for "air foil".
Old Apr 10, 2009 | 02:46 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
On a 350 TPI, its better to get a 52mm throttle body with an air foil already built into it, so you dont have to buy it twice.
Old Apr 10, 2009 | 10:48 PM
Car: 1988 Iroc-Z28
Ahh I see. Thanks for the input!
Pac J
May 17, 2020 10:44 AM
skinny z
Oct 5, 2015 06:23 PM
bjpotter
Oct 4, 2015 07:48 PM
thejimsterz28
Sep 30, 2015 08:52 PM
