87 TPI 5.0 Air foil/idle problem
Car: 87 GTA
Engine: 5.0
Transmission: 5spd
Axle/Gears: 3:45
I had issues with idle sticking on high.After adjust minimum idle and TPS.It's alot better..So i put a airfoil on,and it screwed up my idle big time.Would not come down.I took it off,and the idle is coming back down again.Any clue y the airfoil did that??? I haven't taken off the TB to clean yet,but did clean out the bores best i could not long ago..But i didn't clean out the whole/passage way where IAC goes..Could that be the issue?
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Re: 87 TPI 5.0 Air foil/idle problem
That could definately be your problem. You could also have a leak somewhere in the TB, just make sure you use new gaskets when reassembling it after cleaning.
Iroc8t8
Yesterday 02:06 AM
Sanjay
Aug 12, 2015 03:41 PM
