How to swap a Carb for a TPI?
Old Apr 22, 2009 | 06:53 PM
9chevy2's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
I'm just trying to swap out my 305 carb for a complete TPI, the thing is i don't know what i am doing as far as the wiring goes and would like to know are there any download able installation manuals online or can someone who has been through this can tell me step by step wiring procedures???
Old Apr 23, 2009 | 10:50 PM
Awesome-X's Avatar
Car: 87 Camaro
Re: How to swap a Carb for a TPI?
Honestly you'll probably have to get the whole wiring harness out of a donor car to do it. If you had that and the right distributor, fuel pump, and intake then it should work just fine. You'll need the computer too.
Old Apr 23, 2009 | 11:13 PM
9chevy2's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
well i got the wiring harness and cpu, just need to get the fuel pump. Will the wiring just be easy as pluggin female to male or is it something else.
Old Apr 24, 2009 | 04:04 AM
Awesome-X's Avatar
Car: 87 Camaro
Well if you have the correct wiring harness then yeah, pretty much.
Old Apr 24, 2009 | 05:40 PM
9chevy2's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Can i just use the same fuel pump? If not what kind to get ?
Old Apr 24, 2009 | 05:48 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
you should pm birdtojag he helped me he would help you
Old Apr 24, 2009 | 08:02 PM
Awesome-X's Avatar
Car: 87 Camaro
No, you can't use the same fuel pump unless its originally a tpi fuel pump with a fuel pressure regulator on it. It won't pump nearly enough psi.
midge54
Jan 29, 2017 07:00 PM
gta90
Sep 15, 2015 04:00 PM
86IROC112
Aug 17, 2015 02:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
