Injector retainer clip help
Old Apr 24, 2009 | 06:55 PM
tommygun's Avatar
Car: 1992 Firebird Formula 350
Engine: 5.7 TPI
Axle/Gears: 3.23 Posi
Just wondering how you remove and install the retainers. I couldn't figure out how to remove one, and with all the stuff going wrong with this damn car I yanked it out in a fit of rage with some needlenose pliers, splitting the clip in two. The injector came out though. How on earth do you get the clip in the rail, and the injector inside the clip? I'm going to burn this car.
Old Apr 24, 2009 | 10:47 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: Injector retainer clip help
Rotate the clip and pull it out.
Old Apr 25, 2009 | 04:28 AM
89transam*pearl's Avatar
Car: 89 T/A
Engine: LB9
Transmission: W/C T-5
Axle/Gears: 10 bolt posi, 3.73 Richmond Gears
,,,use a small screw driver and gentlely tap to the right to unlock.
Old Apr 25, 2009 | 08:27 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
GM still stocks the clips as well.
Old Apr 25, 2009 | 10:28 AM
tommygun's Avatar
Engine: 5.7 TPI
Can't find it anywhere, not even the dealer.
Old Apr 25, 2009 | 10:37 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
I think I have the part number around here somewhere.
I just got mine from the stealership about 2 years ago.
Old Apr 25, 2009 | 11:14 AM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Engine: 5.7L TPI> 6.2L
Transmission: 700R-4
Go to any car wrecker and grab acouple of new clips or practice taking them off.
I grabbed like 12 last year cause I found that they can spring off in all sorts of directions while I was taking them off if your not careful.
The easiest is the V6 Gm models..... corsica, beretta, grand prix etc.... they are in plain site.
Brind a flat screwdriver and needle nose pliers and take one side off at a time. Push down and to the side and it'll un-clip.
Take your time....
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
webeeZ28
Sep 14, 2015 12:00 PM
earlpote
Sep 12, 2015 11:55 AM
Keiffer76
Sep 9, 2015 08:52 PM
Ranbo108
Sep 9, 2015 12:20 PM
