in tank to inline fuel pump??
Old Apr 25, 2009 | 10:35 AM
383HSR's Avatar
what do you have to do to switch to an inline fuel pump on a tpi 1991 trans am...can i just take the original sending unit out and just let the intake line in the tank alone and put my inline on??
Old Apr 25, 2009 | 12:05 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Re: in tank to inline fuel pump??
I would like to know also
Old Apr 25, 2009 | 05:23 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
The last time I heard of someone doing this, they were going to take the sending unit out of an early carb'd f-body (82-84) and use that. I imagine you could remove the pump from the sending unit and fabricate a tube to take the place of the pump, though.
Old Apr 25, 2009 | 08:31 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
Does the pump inside the tank act as
a restriction to the inline pump
Old Apr 26, 2009 | 03:46 PM
383HSR's Avatar
yes you can't have two pump they don't work together
Old Apr 26, 2009 | 04:36 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
No, the pump in the tank is not working,
you just suck through it and use the same line
Old Apr 26, 2009 | 04:46 PM
It will act as a huge restriction if you try to pull through the factory pump. You will develop pressure but not volume. It wont run at anything over 2000 rpm.
Old Apr 26, 2009 | 08:36 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
Thanks for the input
Old Apr 27, 2009 | 12:00 AM
No problem. Let us know how it goes!
Old Apr 28, 2009 | 07:10 AM
383HSR's Avatar
so the solution is to take off the sending unit and replace it with what this is where i dunno waht to do lol! can i just put i line in tyhe tank that's it?
Grant2k
Jul 10, 2018 04:01 PM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
AkDrifted
Aug 17, 2015 07:45 PM
Kaweh
Aug 9, 2015 02:54 PM
