1.6 roller rocker advice
Old May 3, 2009 | 08:59 PM
johnny89345's Avatar
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
im changing my valve guides tuesday and was wondering if a set of 1.6 roller rockers will do me any good. the car is pretty much stock btw. will i see a noticable gain and or just waste some cash
Old May 3, 2009 | 09:18 PM
Highhorse78's Avatar
Car: 89 Formula 350
Engine: Built TPI 355ci
Transmission: 700R4 Slushbox
Axle/Gears: BW 9 bolt. 3.27s
Re: 1.6 roller rocker advice
You should notice some improvement if you're running the stock cam. Aside from the added lift, most designs of roller rockers have added durability and efficiency. I've had good results with Comp magnum roller tip rockers on a stock motor. IMO their worth the price...
Old May 4, 2009 | 12:04 AM
Nelz's Avatar
https://www.thirdgen.org/mods3
You can see how much more lift on your cam at the bottom of this page. It's one of the cheaper mods you can do without tearing open the engine to install a performance cam. You'll notice that you come close to some of Crane Cam's "performance" camshift lift numbers (Although they use a 1.5 rocker) by installing 1.6 rockers on a stock block.
After that, just put in some headers, preferably 1-3/4" and and adjustable fuel pressure regulator and bump it up to about 46-50 psi (check your stock pressure and add 10% to that) and be happy because without dumping more money into the heads, cam, highflow runners, and chip, that's pretty much as good as you'll get on a N/A stock motor.
Old May 4, 2009 | 03:21 AM
Chilekesh's Avatar
Car: '89 Trans Am GTA
Engine: L98 - 350 TPI
Axle/Gears: 3.27 BW 9 Bolt
How about valve cover clearance? Are tall covers needed for 1.6 rockers? If yes, how much taller than stock ones?
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
TexasMaro
Sep 15, 2015 06:50 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
