Head confusion
Old May 4, 2009 | 09:15 AM
THE HOFFMEISTER's Avatar
Car: 89 Trans Am GTA
Head confusion
Right,
been thinking if getting a decent set of aluminium heads
for my 89 GTA,
thing is, been looking through summits website and on nearly all
the heads..... in the application part, its states
that they only suit small blocks up to 86!!! wtf
Whats going on here?
Surely a set of edelbrock rpm or some trickflows
would bolt straight on?
What gives?
Old May 4, 2009 | 10:07 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: Head confusion
Are you serious? Aftermarket heads have been discussed a million times. YES they have Edelbock & Trickflows that will bolt up. Do a search and/or call Summit.
Old May 4, 2009 | 10:47 AM
Re: Head confusion
you dont have to be a jerk, ffs
I KNOW you can get heads!!!!!!
Old May 4, 2009 | 10:50 AM
Re: Head confusion
The question was WHY!!!!!!!! they state only up to 86 on all the heads
on summits site!!!!!!
Old May 4, 2009 | 11:20 AM
Re: Head confusion
Originally Posted by THE HOFFMEISTER
they state only up to 86 on all the heads on summits site!!!!!!
Not all the heads. If you have a stock application (which you didn't specify), then you would want something like this...
Per the Summit site:
Edelbrock 60859
Cylinder Head, Performer, Aluminum, Assembled, 60cc Chamber, 165cc Intake Runner, Chevy, 5.7L, 1987-95
These are centerbolt heads and have the EGR crossover.
Old May 4, 2009 | 11:28 AM
the zander's Avatar
Car: 86 Camaro IROC-Z
Engine: 305 TPI (retrofit)
Axle/Gears: Crappy stock 10-bolt gears
Re: Head confusion
the pre/post '86 generally refers to the intake manifold bolt pattern. All of the SBC heads will bolt onto any GEN1 (not LT1/LS1) block. However if you wish to reuse your existing intake manifold you will required a set of heads with the post '86 intake manifold bolt pattern. The center two intake manifold bolts on each side are angled differently. If your thinking of upgrading your intake aswell (i assume your either TPI or TBI right now) to somthing more capable of fully utilizing the potential of performance AL heads then you have free rein to choose whatever heads you like.
-Z
Old May 4, 2009 | 12:40 PM
Re: Head confusion
Ah right, so its the intake bolt pattern that changed after 86.
Didnt realise that happened (hence the confusion)
With the TPI systems been around since 85, didnt realise they werent
all compatible with each other.
Yes, the plan is to upgrade to a higher flowing manifold,
hadnt decided if that was hi-flo tpi or a stealth ram,
tho i see now that either will bolt to aftermarket heads.
Makes sense now,
Thanks for clearing that up for me.
RazorN8
Jan 7, 2022 11:44 AM
FireDemonSiC
Sep 3, 2015 12:31 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
86IROC112
Aug 21, 2015 07:20 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
