Inj Quston
Old May 11, 2009 | 07:42 AM
1quik4's Avatar
Car: 1987 Trans Am GTA
Axle/Gears: 3.73's
Inj Quston
I plan on replacing all my inj becuase I think I have a bad one... What inj do all of you use instead of stock.. I do plan on running NOS (100 shot), I have headers, exhaust, 3.73's....
I hear Ford inj work good, is that true?
Old May 11, 2009 | 10:15 AM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Re: Inj Quston
Ford injectors are great & they will work with your GTA.
Ford type inj's are a tad more audible than the factory injectors, which
doesnt bother us that use them. They just "click" alittle more than I ever
noticed when my car was stock. But I like them alot.
What are your long term plans for the car? Injector selection is important,
so making sure you plan for future endeavors is always a good idea.
Old May 11, 2009 | 10:20 AM
TPI's Avatar
Re: Inj Quston
Besides nos, are you going to play around with the motor?
Old May 11, 2009 | 11:48 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
Re: Inj Quston
you can go into group purchases and last year they got a deal from http://fuelinjectorconnection.com/sh...&productId=134
they are supposed to be pretty good.
Old May 11, 2009 | 12:05 PM
1quik4's Avatar
Axle/Gears: 3.73's
Re: Inj Quston
I may an on better set of heads and porting out the plenum... Not too much beyond that...
I was thinking 30# injectors???
Old May 11, 2009 | 03:04 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
Re: Inj Quston
If that is all your going to do then 30# injectors are overkill and will probably be to much fuel. A nice set of Ford 24# injectors would be great.
KCG
Jun 24, 2020 04:33 AM
TPortFormula
Nov 14, 2001 11:37 PM
doc
Feb 13, 2001 12:37 AM
88 350 tpi formula
Feb 8, 2001 03:39 PM
