what motor is this?
what motor is this?
hello everyone here are some pics of my 92 i picked up. its a tbi but i have this tpi i just got and dont know much about it i was told it was a 350. im going to need a wiring harness and i wanted to make sure i knew what to look for. these where the only numbers on the block i could find it looks like it says 5.8 but i did not know they made i 5.8 i thought it was a 5.7 anyway anyhelp would be cool.
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Re: what motor is this?
Looks like a LG series motor, 5.0.. LG4's were only 305 no?
Probably wrong, It looks like it was intentionally gobbed up by
something! I dont know too much, but it does look kinda funny.
It was a carbed/TBI? engine, converted to TPI.. Take a
head off and measure the bore to tell you what it is, or
Take those numbers to ..I forgot what website its called...
anyone?
anyone?
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Car: 93 Formula,88 T/A,01 WS6
Engine: 93 LT1,88TPI305,01 LS1
Transmission: 93 700R4,88 700R4,01 T56
Axle/Gears: 93 3:73's,88 3:42,01 3:40
Could have been worse......most people see a TPI engine and automatically think it's a Vette motor. At least he did clam it was one of those. And again, he may not know. Or he just took you for a sucker........I'd definatly have that "Little chat"
he did not know it was a 5.0. is the tpi part of the 305 the same on 305 and 350 or is it different? i dont know to much about these. he is currently looking for another motor for me. once again thanks for the quick help on the motor
Car: 1989 GTA, 1985 T/A
Engine: L98, LG4
Transmission: Slush-o-matic 700R
Axle/Gears: stock and stock
The TPI stuff interchanges between 350 and 305...only difference is the injector size. Careful with heads and TPI...the manifold has a specific angle that will only work with 87+ GM heads or aftermarket heads designed to work with this manifold. Also, do you NEED a 350? The 305 TPI will be leaps and bounds more powerful than the TBI. The 305 puts out fine power for a daily driver, but if you want to start eating mustangs and such, than yes, you'll need to step up to more displacement.
Car: 1983 G20 Chevy
Transmission: 4L60
Engine: L98, LG4
Right as usual Fast. I was assuming (perhaps incorrectly) that its an 87+ manifold due to the fact that the block is coded for 88+ as per Street Lethals post. Btw, love the work you've done and posted here and on the fullsizechevy board. Its excellent stuff.
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
ASSuming the engine hasn't been pulled:
8th digit of the vin for;
350 = 8
305 = F
FWIW, that doesn't look like it could be a 7. But who knows. The only definite way is to pop a head.
350 = 8
305 = F
i want to go with a 350 if im going to build it im not going to waist my time on a 305 i can get the correct 350 block easy enough. i dont know what the plans are for the motor at this point i might just get rid of it and get a complete 350 not sure yet
thanks for all the help
