injectors
Old May 12, 2009 | 07:04 PM
camaro3554gear's Avatar
Car: 1991 Z28 (sold), 1987 Buick GN
Engine: L98 TPI, bored 0.040 over
Transmission: TH350, 2400 stall, shift kit
Axle/Gears: 10 bolt w/eaton locker, 3.42 gears
injectors
Can anyone recommend a good, not super expensive replacement injector for a 91 L98? GM injectors are like $800, Im a little worried about using Standard Motor Co. brand injectors. I've never had good luck with any electrical parts made by Standard. Opinions on Accel, or Vemon injectors?
Old May 12, 2009 | 09:50 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Transmission: Built 700R4
Axle/Gears: Unknown 9 Bolt Posi, 3.73s
Re: injectors
Venom sucks. I've heard all bad things about them.
Accel is very good in my opinion, if you want some cheap injectors, I have a set of 24# injectors by Accel that are less than a year old. They aren't the original pound (L98 is 21#) but they still are very good imo. Less than 3000 miles on them.
PM me if interested!
Old May 12, 2009 | 10:03 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
Re: injectors
a l98 uses a 22 in that year, 24's will need a re tune Accel are made by standard
Old May 13, 2009 | 10:03 AM
darbysan's Avatar
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
Re: injectors
I have heard that Accel's can be noisy. I would recommend talking to Jon at FuelinjectionConnection.com (FIC). He is a straight shooter, and will give good advise. I got a set of remanufactured Bosch II's from him, and they work great. They have a video on U-tube that will show you the spray pattern of different brands. Seeing that led me to the Bosch's.
Old May 13, 2009 | 04:51 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Re: injectors
L98 is 21# I Think
Old May 13, 2009 | 09:07 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
Re: injectors
Originally Posted by Z2EIGHT
L98 is 21# I Think
Actually L98's injectors are 22lbs.
Old May 15, 2009 | 04:18 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: injectors
Check out Fuel Injector Connection, they have good prices on reman injectors.
http://fuelinjectorconnection.com/sh...&productId=134
Also, here is a pretty cool comparison video, also done by the guy at FIC:
http://www.youtube.com/watch?v=7oTirEZNRw8
KCG
Jun 24, 2020 04:33 AM
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
webeeZ28
Sep 14, 2015 12:00 PM
