maf diagnostics
Old May 21, 2009 | 10:40 AM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
maf diagnostics
well i am pretty new to diagnostics and even newer to a maf based system. i've got a 1989 camaro iroc-z 5.0 5 speed. its a nice car ,but it runs pretty rough unfortunately. so i figured i'd hook up a scanner to it and see what i can find out. Everything seems to be in check except i'm not realy sure how the maf works and would like a quick description to see where i should go next with this.
so question #1 is the maf sensor a 0-5 volt sensor like most of the others in the engine bay? Should i see a lower voltage reading for less incoming air and higher for more incoming air?
question #2 around how high would a full bolt on 305 peak the mafs airflow if i matted it under a high load, i do know max is 255g but mine doesnt seem to go anywhere near that high.
also 1 other question the block learn is what i should be looking at for long term fueling correct? perfect is 128 i do believe ,but if higher does that mean im richer or leaner?
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
racereese
Oct 3, 2015 03:46 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
