starting problem
Old May 22, 2009 | 11:54 PM
brians88gta's Avatar
Car: 88 gta
Engine: 350 HSR
Axle/Gears: 3:27 borg warner 9 bolt
starting problem
ok so i swapped over to the holley but before i did that it would take a good min to get it to start and now sometimes i think its not going start at all so its not in the fuel system everything is new by holley but just cant figure out why wont it start emediatly if fuel pressure is there. any body have any cues i would be thankful
Old May 23, 2009 | 12:27 AM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
Re: starting problem
Did you change you're electric fuel pump to mechanical. Or did you at least put a pressure regulator in the line?
Old May 23, 2009 | 10:46 AM
Car: 88 gta
Engine: 350 HSR
its fuel injected and the whole fuel system is all new by holley from the pump to the regulator everything is brand new
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
