Where exactly does the O2 Sensor connect with the wiring harness?
Old May 24, 2009 | 09:03 AM
89FRMLA350's Avatar
Engine: None
Transmission: None
I just bought an 85 Trans Am. It has a rebuilt 350 and 700R4. Anyways as I usually do I've pulled all the AC/SMOG/Cruise Control crap out of there when I noticed the O2 sensor wasn't connected to anything. I couldn't find any other loose wires that it may have been connected to. Any help would be appreciated. Thanks
Old May 24, 2009 | 03:44 PM
brians88gta's Avatar
Car: 88 gta
Engine: 350 HSR
Axle/Gears: 3:27 borg warner 9 bolt
Re: Where exactly does the O2 Sensor connect with the wiring harness?
i had the same problem i got the wire diagam at the ecu and ran my own wire from computer to O2 sensor got rid of my rich condition code problem
Old May 25, 2009 | 01:39 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
The O2 wire connector pigtail is in the same harness as the wire for the engine temp sensor, the harness runs along the frame with the fuel lines.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Caspar
Jun 19, 2016 11:19 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Reddeath210
Oct 6, 2015 08:20 AM
