Corvette cam in Speed density rebuild
Car: 1984 Chevy K5 Blazer
Engine: SD TPI 350 w/FIC Bosch IIIs
Transmission: 700R4 4X4
Axle/Gears: 3.08 front and rear w/ 33" AT tires
Does anyone know if I can use a Corvette cam in a stock speed density rebuild without reprogramming my camaro chip?
My TPI is a 1990 Camaro 350 speed denstiy system...
Car: 1983 G20 Chevy
Transmission: 4L60
re: Corvette cam in Speed density rebuild
The L98 Corvette cam is the VERY SAME cam as the 1990-1992 LB9/L98 Camaro/Firebirds.
Thanx for your reply... do you know any ways of making more power with Speed density without reprograming the chip?
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The stock computer can handle simple changes such as a cat-back exhaust, cold-air intake, etc. But a cam or heads swap will probably require a custom chip, no matter if its MAP or MAF.
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Corvette cam in Speed density rebuild
Thats all good, except when reading his signature, I noticed he was running the TPI in a 5,000 lbs K5 Blazer. Thats where the tuning will differ. I started my TPI 350 in the Van with a custom tuned .bin from Z-Industries. It had more than a little detonation from the timing advance table. Even the stock AUJP Timing table had too much advance in it at lower rpms and higher loading.
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
hahha, CORVETTE? come one, its all about crane radical cams with rhoads hydraulic lifters, an advanced mechanical timing gear drive with the knock sensor delete, and a resistor in place of it. running a 50000volt coil and forced ram induction. open exhaust and custom chip. all of which is bad for my LB9 but a dude like me can dream. someday man.. but ya corvette cams are pretty chill, i was going to do that to my pickup, but decided not to, i heard those cams are brittle. idk i rolled it anyway.
