Ported vacuum source
Old May 30, 2009 | 12:38 PM
norcalace's Avatar
Anyone know if or where a ported vacuum source exists on TPI motors?
Old May 30, 2009 | 04:53 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Ported vacuum source
Any of the vacuum ports in the back for the fuel pressure regulator, the a/c and cruise control, or the brake booster?
You can T into the a/c and cruise control vacuum ports fairly easily.
Old May 31, 2009 | 01:52 AM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
i hate cruise control, hahaham its like that scenerio when the cars come alive and take humans life. I had a cruise control seize up out of the blue. kept increasing my speed on a 35mph zone to 65-70mph. i have it disconnected ever since. even the previous owner warned about it, but i didnt believe him. i got cruise control still installed but i just removed the linkage. considering your Vacuum REZ is in the bumper, i recommend doing a T-fitting and using a check valve rite by it. PEACE
Old May 31, 2009 | 01:33 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
None of those are "ported" vacuum. I don't think there are any on TPI.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:14 PM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:13 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
