Anyone have UMI STB and poly enigne mounts?
Old May 30, 2009 | 08:41 PM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
I had the Kenny brown STB on my car for a while and when i put poly mounts in it started rubbing. Looks like the UMI might have alittle bit more clearance. Is anyone running this? I also have SLP runners not sure if that matters though.
Old May 30, 2009 | 09:10 PM
Stephen's Avatar
Car: 87 GTA
Re: Anyone have UMI STB and poly enigne mounts?
My UMI STB has a pretty decent range of adjustment on the mounts, which could raise & lower the height of where the cross bar ends up. Not a WHOLE lot, but some, at least. I'd guess a good 1/8"-1/4" of difference.
I first mounted mine up as low as possible, to clear my GTA hood, which is doesn't, and while it cleared the TPI plenum, apparently it wasn't enough after the engine torqued over while driving.
I now have a 1/16" deep "scar" that I'm currently trying to sand the top of the plenum down smooth, to get rid of the groove the STB made.
It was a test mount for UMI & expected not to clear the GTA, which we confirmed with my car.
Old May 30, 2009 | 09:11 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
I have a OEM TPI motor and poly motor mounts. My UMI STB clears the plenum but is close. Does not rub.
Old May 30, 2009 | 09:14 PM
91RS5speed's Avatar
Car: 91 RS
The kenny brown stb i had on the car cleared but would rub from the flex.
Old May 30, 2009 | 09:35 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i assume this is going on the camaro? the fitment issues that Stephen mentioned, are for the firebirds, trans am and gta in particular. Camaros do not have this issue.
You should be fine
J-money
Jan 4, 2019 09:45 AM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
luvofjah
Sep 10, 2015 10:41 AM
UMI Performance
Sponsored Vendors
Sep 4, 2015 09:22 AM
UMI Sales
Sep 4, 2015 08:39 AM
