Pressure in Gas Tank
Old Jun 2, 2009 | 11:00 AM
darbysan's Avatar
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
I have ande Elky with a recent TPI swap. Everyting is running great, but I noticed yesterday that when I went for Gas, there was a significant amount of pressure ( not vacumn) in the gas tank when I unscrewed the cap. I was expecting some vacumn, due to the canister purge. Any thoughts? Did I hook up the canister purge to the wrong spot on the throttle body ( hooked it to the second (lower) outlet on the passenger side of the TB).
Old Jun 2, 2009 | 11:17 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Pressure in Gas Tank
Some pressure is normal. I couldn't say how much is significant.
JamesC
Old Jun 3, 2009 | 01:25 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Sounds normal to me. My tank has hissed more than any other car I've owned, right from brand new. On really hot days (100°), it will sent a wave of heat out after taking the gas cap off.
I had to laugh getting my gas cap pressure tested for emissions testing. It's obvious that it's going to pass.
Old Jun 3, 2009 | 02:35 PM
Guest
Guest
Posts: n/a
If it wasnt originally FI (I presume not by your info, says 85) the fuel sending unit does not have a provision for a vent. Did you swap out your sender? The stock setups in the F-body have the charcoal canister line and a line running to a fuel tank vent valve, besides the fuel pressure and return so there are a total of 4 lines.
chazman
Aug 28, 2018 03:25 PM
Infested
May 22, 2018 11:56 PM
Andrew6.688
Dec 13, 2015 10:59 AM
chazman
Aug 22, 2015 02:01 PM
AkDrifted
Aug 17, 2015 07:45 PM
