1988 irocz 100 original miles mint
Old Jun 27, 2009 | 07:30 AM
  #51
7998's Avatar
Car: '91 Z28 'Vert
Engine: 5.0 TPI
Re: 1988 irocz 100 original miles mint
Jeez what a whine fest. I too got sucked into thinking I was going to see an original '88 Iroc. But it turned out to be a nice "period" custom instead.
Good luck with the car and just drop the tank.
Old Jun 27, 2009 | 08:20 AM
  #52
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
the thing about the internet is there is ALOT of people on here so you cant expect everyone to be nice. and this post is comming off as an attention grabber because it to me it basically says "how do i change the fuel pump in this car? i already did it a little while ago on the same type of car. watch this video." dont be turned off from the site because of it this is a good site with alot of good free help.
Old Jun 27, 2009 | 09:37 AM
  #53
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
im going to cut a hole for my fuel pump access but yours if different.
if its an original 88 with only 100 miles then dont touch it at all.
drop the tank and fix it and leave everything just like it was new.
Old Nov 7, 2010 | 02:28 PM
  #54
minzzz21's Avatar
Hate to bring an old hated thread back but,As i read this post as what I said and responded I apologize to everyone Involved.I have no idea why i said what i said in the thread and named it mint i-roc 100miles.If i was to redo the thread,I would of made it need advice on fuel pump not all the bs i wrote.I guess i just wanted the attention lol.Anyway back to the car.Dropped the gas tank,Unfroze the fuel pump,cleaned it all out and the car ran.Took about 2-3 hours.The whole muffed was rotted out i guess from sitting so long.Did all this back in august.Im just glad there was no bearing knock.Now I start the car once a month and let it run.Thanks for all the advice
Old Nov 8, 2010 | 07:27 AM
  #55
the blur's Avatar
How does one unfreeze a fuel pump ??
& yes, those gas tanks are bad. your garage will fill up with fumes eventually.
Old Nov 8, 2010 | 11:10 AM
  #56
stealth908's Avatar
Car: 87 GTA
Engine: tpi 350
I bet it was stuck from sitting for years. My Formula 350 sat for over 5 years, and it forze up. You can work the blades in the pickup and it will sometimes free up the pump, but I bet the pump goes bad REALLY fast. Mine did, and I cut an access whole in the hatch area to replace it. I had no choice. I had to get it changed on the side of the road, so I didn't have access to the proper place or tools to change it. I will definately NOT cut a hole next time. It's just not worth it. Get the car on a lift and take 3 hours to keep the car intact. My 2 cents.
Old Nov 8, 2010 | 11:14 AM
  #57
the blur's Avatar
any one who goes through the effort, and does not REPLACE the pump is
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
kyleb24
Aug 15, 2015 08:24 AM
Zachattack0925
Aug 12, 2015 09:52 PM
kyle5647
Aug 7, 2015 03:08 PM
