Fuel line fitting?
Old Jun 11, 2009 | 10:21 AM
blackbirdta's Avatar
Fuel line fitting?
What type of fitting connects the fuel hard lines to the rubber lines from the engine? Do they push together like the 4th gens or are they threaded? If threaded what thread? Thanks!
Old Jun 12, 2009 | 02:07 AM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Re: Fuel line fitting?
They are threaded, no idea on the size off hand though.
Old Jun 12, 2009 | 06:42 AM
Thanks gearhead...that helps
Old Jun 12, 2009 | 10:33 AM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
they are saginaw fittings. metric o-ring. I think the thread is something like 14mm and 16mm, but i'm probably off a bit.
if you look up adapters for fuel lines from any of the AN supply type vendors, you can easily find the thread size and pitch.
pep boys etc will also sell short sections of replacement fuel lines that have those fittings, in case you need them.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
