Vacuum Ports
Old Jun 17, 2009 | 02:12 AM
lbackr40's Avatar
Car: 1992 Heritage Edition Z28
Vacuum Ports
There are two vacuum ports on the passenger side rear of the tpi plenum, one for the MAP sensor and one for the fuel pressure regulator hoses. Does it matter which hose plugs into which port? I have found conflicting information on the factory routing and the supplied vacuum diagrams don't show much.
Old Jun 17, 2009 | 05:32 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Vacuum Ports
If the hoses fit both nipples it technically doesn't matter. They're both supplied by the same source.
The MAP sensor should have a boot that really only can fit onto one of the nipples due to how it's been formed.
You should have 3 nipples back there.
MAP
FPR
HVAC/Cruise Control
Old Jun 17, 2009 | 06:26 AM
lbackr40's Avatar
Re: Vacuum Ports
Got it. The FPR and the MAP are the same size ports. The third (furthest forward) is larger and not as offset.
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Mark_ZZ3
May 24, 2018 01:02 PM
sammy52401
Nov 11, 2015 07:20 PM
Reid Fleming
Oct 10, 2015 09:56 PM
