Fuel problem, stalling.
Old Jun 23, 2009 | 01:52 PM
Evader15's Avatar
Hi,
I have a 1985 Trans Am 305 TPI. The car stalls when going around corners, hard stops, down hills. I replaced the fuel pump and still have the carpet off and i can hear the fuel pump very well. The only problem is i dont hear it at all when the car is about to stall. It sounds like the fuel pump just cuts out and then the car stalls. It will start right back up if and run great. It also does not prime, but has not been priming for about a year.
If I jump the two end wires on hte fuel pump relay and the fuel pump is turned on by the jumper wire it does not seem to stall out. Without the jumper wire it stalls all the time.
Things checked:
Fuel pump
Vacuum lines
Relay
Not checked:
Fuel filter (looks newer)
EGR
FPR
Fuel pressure
ECM?
Where should i start?
Old Jun 25, 2009 | 02:20 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
Re: Fuel problem, stalling.
Replace the fuel filter anyway. It could be installed backwards by a previous owner, or just wiped off to look new.
I would check the fuel pressure next.
Old Jun 14, 2010 | 04:46 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
any updates ?
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
killer777
Aug 8, 2015 02:47 PM
