Engine Identification
Old Jun 26, 2009 | 05:54 PM
25th92RS's Avatar
Car: 1992 RS, 2000 Z28
Engine: LO3 with TPI Swap, LS1
Transmission: 700-R4, 4L60E
Axle/Gears: 3.42 with TruTrac LSD
I'm looking at buying a 91 Z28 parts car for the L98 in it. By the VIN number it is a L98 car. The guy who is selling it had bought it without a motor but bought a L98 out of a 1990 Firebird for it. Before I buy this car I want to make sure it really is an L98. Visually, the 305 and 350 are identical. Does anyone know what actually identifies the block as a 350 without tearing it down and measuring the bore or stroke? I know there are ID numbers stamped in behind the drivers side cylinder bank, but I can't seem to find a very credible source for what is what. Everyone seems to have a difference in opinion. If someone can get back to me asap that would be great, I'm going to look at this car again tomorrow.
Old Jun 26, 2009 | 05:58 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Engine Identification
Check the casting number on the block behind the driver side head.
Old Jun 26, 2009 | 06:04 PM
25th92RS's Avatar
I knew that part but I would like to know if anyone knows what numbers mean what pertaining to a 350 block compared to the numbers on a 305 block
Old Jun 26, 2009 | 07:32 PM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
Usually behind the left head will be a casting number and either 5.0 or 5.7 on most late model blocks. If the 6.0 or 5.7 are missing, look up the casting number on the web.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
