dies when slowing down
Old Jun 26, 2009 | 06:47 PM
camaronut396's Avatar
Car: 1989 Iroc-z Camaro
Engine: Procharged 383 Holley Stealth Ram
Transmission: Soon to be ATI TH400/Borg Warner t5
Axle/Gears: Moser M9 4.86
i have a 1989 iroc that i put a 1991 5.7 tuned port in, and now its giving me some issues.. When i did the engine swap i put a new fuel pump in, now when i drive around , it starts making a loud howll noise, then stops for a minute..
also the big issue is that it was out of a automatic car and my car is a manual, so if i am driving along and put it in neutral, and as im coasting the engine will just die.... so idk what its deal is. then it will start right back up.
i replaced the map sensor few weeks ago, replaced the iac a little while back, and checked my tps voltage.. so i dont know what is up, if it is the injectors, fuel pump, fuel pressure regulator, or a bad map sensor or something else. also dont know if it is ignition, or something to do with fuel...
when i checked the fuel pressure today, when i turned the key it went to 40 psi, then right when the fuel pump stoped, it went to 0 psi almost imidiatlley.....Well if someone could help me out that would be great. Thanks
Old Jun 26, 2009 | 07:47 PM
89iroc-z559's Avatar
Car: 1989 camaro Iroc-z
Engine: 5.7 Tpi
Transmission: 700-R4
Axle/Gears: dont know what this
Re: dies when slowing down
check the fuel injectors and the computer the same happened to mine and that fixed it
Old Jun 26, 2009 | 08:06 PM
how do i check the injectors? and also the computer?
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
bjpotter
Oct 4, 2015 07:48 PM
Luigytico09
Oct 1, 2015 08:46 AM
