What Type of Spark pug wires are theeee best??
Old Jun 30, 2009 | 03:57 AM
1986iroc350's Avatar
Car: 1986 Iroc z
Engine: 350 tpi
I currently have Accel Wires on my 86 iroc 350. YES its a 350 in an 86. and its TPI. I am looking for new wires when i do a my next tune up. I have an Accel dist. cap. rotor and coil. The guy that had the car before me has put accel wires on there. But i dont know which ones are the best. 8mm or what ? can you guys give me any suggestions? Thanks
Old Jun 30, 2009 | 08:11 AM
92GTA's Avatar
Re: What Type of Spark pug wires are theeee best??
MSD 8.5mm, buy the custom kit so you can make your own. I've been using the grey ones for 7 years, 100,000 miles and they are still perfect aside the heat cycle effects on the metals which is why I will replace them soon.
Old Jun 30, 2009 | 09:09 AM
89FRMLA350's Avatar
Engine: None
Transmission: None
I've always used the MSD 8.5 on mine. I know its not much but they have worked well for me.
Old Jun 30, 2009 | 09:50 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
I use MSD 8.5's as well, and would recommend if you want to tackle the job, to cut and crimp your own set. MSD sells bulk kits or universal kits that allow you to do this. I plan to do this sometime as well, as my wires will be of perfect fit and not dangling in some areas as they do now.
Old Jun 30, 2009 | 12:29 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
I did not see headers listed as being on your car. If you dont have headers go buy a decent stock set of wires and delco plugs from napa or autozone. If you have headers I would use accel 8mm universal wires and cut them to fit properly. I have headers and have used the accel 8mm wires for a few years now and have no complaints.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
g.l.mos
Aug 22, 2015 12:02 AM
Bryan F
Aug 18, 2015 02:28 PM
