Ford Injecter in a TPI
Old Jul 9, 2009 | 10:42 AM
Chris`s85Z28's Avatar
Car: 1985 Z28
Engine: LG4 305 with a few modds
ok, i have 8 injectors outta a 5L mustang, i heard they`ll work in my 350 TPI which is in a 1990 GTA.
i don`t know what Ibs they are though, there orange tops and the numbers are E6TE-A2B on one side and 195500-1153 on the other side. will these work in my 90 350 TPI?
Old Jul 9, 2009 | 07:48 PM
1986 iroczzzzzz's Avatar
Re: Ford Injecter in a TPI
i put some ford mustang injectors in my 86 305 tpi. bored .030, with comp cam. works great. i know the mustang and 305tpi injectors are both 19lbs, the 350 has 22lb injectors. i would say that they would work if your motor is pretty much stock
Old Jul 9, 2009 | 09:15 PM
Abubaca's Avatar
My ford FI's are blue topped 24 pounders. My guess (and I stress GUESS) is that yours are 19 pounders which is NOT enough for your 350, which wants 22 pounders.
.....I'd say no.
Old Jul 12, 2009 | 07:29 PM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
19lbs injectors will be fine. Will need to bump your fuel pressure to 46psi. Just putting them in will have the car work, but won't get the exact power potential out of it. I used 19lbs injectors in mine until I got LT1 injectors. Had no problem with anything.
Old Jul 13, 2009 | 10:15 AM
Car: 1985 Z28
well, the thing is i`m trying to pass e-test, i have 8 LT-1 injectors in the car 4 went bad and i failed my e-test, right now i couldn`t care less about lossing power, i just wanted to know if they`d work in my 350, and not cause engine damage cause there too lean at 19 lbs.
any GM V6 injector that would work in my engine.... yes i know WTF am i thinking trying to put V6 injectors in my car, but i`m very very poor and have to use what i can get and GM v6`s are a dime a dosen
Old Jul 13, 2009 | 12:28 PM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
i'd use the ford ones if you have them for sure over the v6 ones
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
toronto formula
Nov 10, 2015 06:17 AM
86Base
Aug 13, 2015 05:06 PM
Sanjay
Aug 12, 2015 03:41 PM
