new fuel pump, filter, good pressure, lean as hell on idle??
Old Jul 13, 2009 | 05:14 PM
thunder85's Avatar
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
Ok, here's the deal: fuel pressure wouldn't kick up over 25psi max so i changed the fuel filter (no difference) then the fuel pump (new walbro high volume). checked the afpr and it was good, so I reassembled and now i have great fuel pressure (adj to 40 with vac line off), no obvious leaks or anything but my afr at idle is hitting 18-19.5 and its sputtering as you can imagine running that lean. when I pick the rpms up the afr straightens out, and when i hit it afr drops to the 11-12 it normally does under PE.
I was getting 14.9-16 afr at idle with the pressure too low, so this is confusing the hell out of me. any ideas?
Old Jul 14, 2009 | 07:36 AM
thunder85's Avatar
Engine: 5.7L w/hsr
Re: new fuel pump, filter, good pressure, lean as hell on idle??
anyone? i'm seriously stumped here
RazorN8
Jan 7, 2022 11:44 AM
9192camaro
16
Feb 3, 2019 12:21 AM
justin57
Aug 20, 2015 07:05 PM
Kaweh
Aug 9, 2015 02:54 PM
