Can't get car to idle or run right
Old Jul 14, 2009 | 05:11 PM
skyrunnr28's Avatar
I have a '91 Z28 with a 5.0F that I can't seem to get it to run right. It started running rough only when hot about 2 weeks ago, than last Monday it wouldn't start after comming out of a store. After about 3 hours I got it to start than got it home. I started going over Ignition and fuel components, finding that 5 of the injectors had resistance readings from 1.9 - 5.0 ohms. So I ordered a set of LB9 Bosch III injectors from FIC. I replaced the injectors and its running a little better but I'm still having problems with a rough idle and lack of performance. It seems like the right bank of injectors are not wirking properly. When I disconnect #8 injector the idle raises instead of dropping, with not much of a change n RPMs on 2, 4, or 6 either.
I am also not getting any codes from the computer.
Any help or suggestions would be greatly appreciated
Old Jul 27, 2009 | 12:11 PM
skyrunnr28's Avatar
Re: Can't get car to idle or run right
Well I figured out what the problem was. I'm posting this just in case someone else runs into the same problem. I found one of the injectors was stuck open, and dumping fuel into the cylinder. Ended up with 3 quarts of gas in the oil. The injector was spraying fuel all the time even when the plug was disconnected from it.
Hope this helps somebody in the future.
specialized
Jun 18, 2022 09:26 AM
RazorN8
Jan 7, 2022 11:44 AM
camaro71633
Sep 1, 2015 10:24 AM
squiggy2
Aug 9, 2015 09:30 PM
