TPI swap, primary fan failure
Old Jul 15, 2009 | 05:30 PM
Daniel Doerksen's Avatar
Car: 1986 T/a
Engine: 5litre TPI
Transmission: T-5 5speed
Axle/Gears: 3.42 1999sscamaro torsen lsd
hey, im just finishing up my tpi conversion. its a 1990 5.0l tpi (4speed auto) into a 1986 T/A (5 speed standard). now i have power to my primary fan relay. but the pin on the ecm darkgrn/wht, that energizes the relay isnt doing just that.(it is pulsing voltage thorugh it) if i skip ecu and apply power at the relay on drkgrn/wht. fan turns on. sooo, this leads me to wonder why it isnt turning on. i know with autos the ttc solenoid turns off the fan when in fourth. so i assuming my problem is that. so i traced the 4th gear switcth the ecm. and its hot supplying battery voltage. i looked at the wiring diagram to see what happens with it when in fourth and it shows it as open. so should i ground the ecm 4th gear pin thats hot? the pin is ltblue d14.
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
gwade12
Aug 8, 2015 08:17 AM
