Coolant temp sender part number?
Old Jul 24, 2009 | 10:40 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Howdy all, i'm going nuts here. I'm trying to get my coolant gauge working with my LT1 swap.
Now on my old L98 it was the 1 wire sender on the driver side head. However every part store I have been to, or talked to today seems to only list parts for the Fan switch on the pass. side, or the coolant temp sensor on the intake that feeds the ECM its info.
I did find a reference in one thread I searched here, and the PN# listed was MPETS6641SB. However, that Part number turns up nothing on any of the online stores I looked at.
Does anyone know what the part # for this would be? All of the parts store guys think i'm insane for thinking my old engine had 3 seperate coolant sensors/switches but I know it did. The parts they were bringing to the counter were all standard 2 wire Coolant temp sensors for the ECM, and not the 1 wire sender for the gauge.
I found a part# WT3000Z which might be it, but I can't find any pictures or descriptions beyond "Coolant Temp Sensor". And none of the parts stores had one in stock for me to look at.
If this gets any stranger I may have to junkyard the sender.
Old Jul 25, 2009 | 09:36 AM
Kodfish's Avatar
Car: 1990 IROC
Engine: 5.7 TPI
Re: Coolant temp sender part number?
I found this on the autozone website; part # TU66. It looks different to the cool fan switch and the coolant temp sensor to the ecm. Instead of a round plug, it has a flat one from the looks of the pic, check it out and see if that is what you need.
Old Jul 25, 2009 | 10:07 AM
That might be it, at least its only $10 if its not the right part. I'll have to pick it up.
Much thanks.
Old Jul 27, 2009 | 03:16 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
That is the usual spot for the fan switch on TPI cars, maybe someone relocated it
'89 gauge sender unit
Standard Motor Product # TS76
$29 from Rockauto
pic here
http://www.rockauto.com/catalog/moreinfo.php?pk=929301
AIRTEX Part # 1T1008
$20 from Rockauto
Old Jul 27, 2009 | 08:24 AM
$29 from Rockauto
pic here
$20 from Rockauto
My old 89 TPI harness had the fanswitch connector on the passenger side, and the harness wasn't modified. Perhaps it was located in a different place on the other years. But on my 89 the factory location for the fan switch was the passenger side with the sender being located on the driver side.
In any case, Autozone PN# TU66 is indeed the part I am looking for, bought one yesterday.
1992 Trans Am
May 10, 2023 07:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
dcbsracing007
Aug 18, 2015 07:24 AM
IrocZ'85
Aug 17, 2015 06:24 PM
armybyrd
Aug 10, 2015 09:23 PM
