About to Replace Injectors Any Pitfalls I should Watch For?
Old Jul 24, 2009 | 02:46 PM
Slowridr's Avatar
Car: 1987 GTA Vert & 1991 GTA 5 Speed
Engine: 87 GTA-L98 91 GTA LB9
Transmission: GTA-700R4 & GTA T5
On L98, probably no diff w/ LB9 anyway
Replacing injectors, while I am at it I will obviously
  • replace gaskets for intake (lower and upper)
  • fuel rail washers etc
  • fuel pressure regulator
is there anything else I should do while I have this thing tore apart to this extent?
Are there any tricks to use when pulling the injectors that would make things go easier.
How bout reassembly anything I need to atch out for?
Old Jul 25, 2009 | 05:23 AM
89transam*pearl's Avatar
Car: 89 T/A
Engine: LB9
Transmission: W/C T-5
Axle/Gears: 10 bolt posi, 3.73 Richmond Gears
Re: About to Replace Injectors Any Pitfalls I should Watch For?
It's pretty straight forward....just make sure to move the retainer clips to the open position...
Also, now would be a good time to port and polish the runners and plenum.
Old Jul 25, 2009 | 07:23 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
When installing the new injectors, put a small film of motor oil on the rubber seals. This will allow the injectors to snap into the rails and manifold easier. Plus its good for the seals.
Hope this helps!
Old Jul 25, 2009 | 05:34 PM
Slowridr's Avatar
Port and Polish I assume is cleaning the inside of the runners real good and using some sort of compound on them to help air flow thru real well.
Old Jul 26, 2009 | 03:44 AM
Car: 89 T/A
Engine: LB9
There are some awesome step by step tutorials on this site to P & P the intake, just do a search.
Old Jul 26, 2009 | 09:00 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
What injectors are you going to use?
Old Jul 26, 2009 | 06:52 PM
Slowridr's Avatar
This is what I was planning to go with. Anything wrong with these?
http://fuelinjectorconnection.com/sh...d&productId=56
the gaskets and orings
http://fuelinjectorconnection.com/sh...&productId=172
or how about this, wouldnt need all of them but will have what I need
http://cgi.ebay.com/ebaymotors/CAMAR...A1%7C72%3A1171
then I may just go to napa and get everything local except for the injectors.
Old Jul 26, 2009 | 07:13 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
port your plenum dog. grind down the two lower lips right at the mouth of the plenum. Also grind a little on the inside of the wall at the mouth.
Old Jul 26, 2009 | 08:43 PM
regal301's Avatar
Car: 1988 iroc-z
Engine: 350 Vortec TPI
Axle/Gears: 3.73 4th gen Torsen 10bolt
i bought the injectors from them also,they run excellent,i bought the 22lb hr bosch II for my 350 .from my experience there stuff is top notch.and like the the post above me pull off the throttle body and you will see two small ramps at the bottom get a carbide burr tool and die grinder and have at it.if you go with the 24 lb you will need a chip burned.my car ran great after,my car had the original injectors at 160k.
Old Jul 27, 2009 | 08:51 AM
Mongoose's Avatar
Car: 90 Formula
I went with their Bosch design 3 injectors.
Old Jul 27, 2009 | 08:56 AM
Slowridr's Avatar
I know this sounds stupid but can you really tell a diff right away when driving it?
1) With the new injectors (mine not faulty right now, just old and I figured while I have it apart might as well do it)
2) With the porting and polishing
I guess I am wanting to know from those that have done either, or, or both. Car is basically stock right now except for no cat and new exhhaust.
The car ran pretty good for about 3 mths after getting it (it sat a while before I bought it) then I noticed it leaking antifreeze around lower intake gasket and leaking fuel from fuel rail at the front drivers side where one of the orings are. It def has low vaccum had it checked. The car cranks right up idles well but when you drive it it just stalls right out like its choking, getting no fuel, it even smells like its running lean sometimes. So I stoped driving it until I could get this done. Thought I should start with leaks espicially the fuel leak.
What do you all think of this for porting and polishing?
http://cgi.ebay.com/ebaymotors/ws/eB...%3AMEWAX%3AVRI
Old Jul 27, 2009 | 08:59 AM
regal301's Avatar
Car: 1988 iroc-z
i did,with the injectors the idle smoothed out,throttle response,and all around driveability,i dont think you will FEEL anything from the porting.
Old Jul 27, 2009 | 09:01 AM
SystemX's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: 5.7L L98
Axle/Gears: 3.27:1
I Went with the Bosch III's also. Very easy to swap. You won't need the clips to put them back in.
I only removed the upper plenum so I couldn't take the fuel rail out completely which made a for a little more work but saved on gaskets. I actually didn't have to buy any gaskets because the upper plenum gaskets came with the AFPR I bought.
Good luck jsut remember to make sure you get all of the old O-rings out of the fuel rails and lube up your new ones with a little vaseline.
BTW: fuelinjectionconnection.com is the way to go. Very affordable and the man knows his stuff!
Old Jul 27, 2009 | 09:24 AM
Mongoose's Avatar
Car: 90 Formula
I pulled tubes and all since I also swapped the OE tubes for a set of ported SLPs. Definitely noticed a difference immediately on the first test drive.
Old Jul 27, 2009 | 10:32 AM
thunder85's Avatar
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
when i got the bosche type III injectors from Jon I definitely noticed an improvement in mileage and idle. he and his guys make a good product. use dishsoap to lube the o-rings like he says to do.. works great and doesn't leave a residue or mess with the o-rings.
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
Bryan F
Aug 18, 2015 02:28 PM
