EGR temp sensor has been discontinued
Old Oct 7, 2009 | 05:01 PM
  #101
BigWhiteGTP's Avatar
Car: 1994 Trans Am
Re: EGR temp sensor has been discontinued
Post it up!
Old Oct 7, 2009 | 05:17 PM
  #102
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
see posts 51 and 53, its already posted :P
Old Nov 5, 2009 | 01:18 PM
  #103
scotts88gta's Avatar
Originally Posted by Chevy86 IROC-Z
So then I dont need a EGR with the EGR Temp sensor right? All I need is the caddy EGR temp right? The caddy doesnt come with a temp sensor right? WWWWWWOOOOOOOWWWWWWW. Boy am I confused. A vacuum switch to replace the EGR Temp switch. Maby too much to ask for but could you draw a picture or a diagram to show what connects into what? Im severly confused. Your method sounds like I would like to do it your way but, I need to better understand whats going on before I make the mods.
I found a place for the egr temp sensors
Just got the first one in the mail and ordered a 2nd for future purposes.
$16-18 bucks on ebay. They have a website but it wasnt working right now, so you might be able to get it cheaper there.
The store name is autopartauctions.
Its there own aftermarket product. Company name is ultra-power fuel injection.
Good luck!!!!
Old Nov 5, 2009 | 01:35 PM
  #104
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Gonna check it out. Thanks Bro.
Old Nov 5, 2009 | 02:22 PM
  #105
If I wasnt clear in the location, here is the item number on ebay. 170402077653
Im sure they have more however, only one is listed right now, since I took the other one.
Old Nov 6, 2009 | 09:02 AM
  #106
87bucketgta's Avatar
Car: 87 GTA
Engine: 5.7
Transmission: auto
i just got one, already sent me a tracking #
Old Nov 9, 2009 | 01:21 PM
  #107
Car: 87 GTA
Engine: 5.7
Transmission: auto
got mine today, looks perfect, jump on it if you guys need one!!!
Old Nov 9, 2009 | 04:21 PM
  #108
Iceman w/ a TA's Avatar
Car: 1989 Trans Am
Engine: LB9
I ordered one and received it from the ebay site listed a few posts up. Just to add some more info the box has the brand ultra-power fuel injection and uses the standard motors #ETS2. I found the ultra-power fuel injection website http://www.ultrapowerfuelinjection.c...let/StoreFront but the online store was down.
Old Nov 9, 2009 | 07:52 PM
  #109
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
I just ordered one. Should have it in about three days. Good find scotts88gta!! I am not sure if they are remaking this or this is just old stock a supplier purchased but hopefully it is being produced again.
5 months after I started this post, I can finally turn my check in engine light off!! Yeah!!
Old Nov 9, 2009 | 09:21 PM
  #110
Chevy8588's Avatar
most likely someone is making them now, typically what happens is when a supplier deems a part not worth making anymore they will sell off the dies to make them VERY cheap, another supplier will pick them up and make them for much cheaper than they used to to be
Old Nov 10, 2009 | 07:39 PM
  #111
burnout88's Avatar
Car: 88 IROC
Looks like it is old surpus stock and not a new reman. I figured out where the part is actually coming from. I noticed paypal payment was sent to a company called http://www.surplusparts.com/. They are a huge parts clearance hose in TX.
Better get one while you can.
Old Nov 14, 2009 | 09:13 PM
  #112
burnout88's Avatar
Car: 88 IROC
got mine today. Is brand new in the box, looks perfect. I noticed the company selling them has been raising the buy it now price. It's up to 40.00 bucks.
Old Dec 1, 2009 | 07:51 PM
  #113
fltche1's Avatar
Car: 1986 Trans Am
alright so let me see if i got this straight.... i have an 86 trans am with the TPI 305. My car idles fine and smooth but it will drop down below 500 rpms and die. i have a code 33. I have gone through the mass air flow sensor system and replaced a bad relay. everything within the MAF system is now functioning. I replaced my vacum lines today and that helped smooth it out but it is still dying when im sitting at idle for periods of time like at a stop sign or a stop light. code 33 is rough idle or MAF system. I went through the trouble shoot for the EGR silleniod (i know i mispelled that sorry) and the silleniod is bad. I have heard that a egr silleniod from an 88 caddy deville with either a 4.5 or a 4.9 would work and plug right in. well the connector on the wiring harness has two pins and the inside connector on the egr has 2 pins as well... both are the male connectors... so what did i do wrond and does anybody know if i am on the right track to fixing my car? Thanks guys
Old Dec 1, 2009 | 08:53 PM
  #114
IROCmenace's Avatar
Car: 1988 IROC
Transmission: 700R4 Silver Dart
Axle/Gears: 3.70 posi
You need the pigtail that goes to the new solenoid. Splice it into your old EGR solenoid harness.
Old Dec 1, 2009 | 09:26 PM
  #115
fltche1's Avatar
Car: 1986 Trans Am
i see. well thanks for the info. sounds like i have a little more work to do then. Just out of curiousity... if i jerry rig the caddy egr so that i can test the principal would it kill the egr?
Old Dec 1, 2009 | 10:00 PM
  #116
burnout88's Avatar
Car: 88 IROC
So is this what your original looks like compared to the caddy one. Also the Application was a 1995 cadillac deville with the 4.9l not an 88
Attached Thumbnails EGR temp sensor has been discontinued-egr-soleniod-camaro.jpg   EGR temp sensor has been discontinued-egr-soleniod-cadillac.jpg
Old Dec 1, 2009 | 10:41 PM
  #117
IROCmenace's Avatar
Car: 1988 IROC
I wouldn't think it would kill the EGR, only vacuum applies to the EGR and all this should do is cycle the vacuum going to the EGR.
Old Dec 1, 2009 | 10:46 PM
  #118
Chevy8588's Avatar
thats very odd my 1988 camaro parts car had the later connector (same as the caddy one) weird..... regardless with the new one it will work and the part should be available for at least another 10 years (we hope) also if the solenoid is stuck open, his EGR valve will be stuck open, introducing wxhaust gases into the manifold at idle
Old Dec 1, 2009 | 11:15 PM
  #119
fltche1's Avatar
Car: 1986 Trans Am
Yep thats exactly it. i have the old connector on my ta like the one you showed on your camero and the caddy one is just like the one you showed in your picture. I will go find that pigtail then and get her wired up so that is working right and i should get some of my fuel millage back. hmmm maybe it is the IAC then that is killing my idle...
Old Dec 2, 2009 | 12:17 AM
  #120
Let us know if the new solenoid fixes your idling issue (engine stall). I seem to have the same issue. I got a code 33 but Im going to test the MAF Sensor when I get a chance. By the way, did you test your MAF Sensor? If not, here is a guide to see if your MAF Sensor is bad. Enjoy.
https://www.thirdgen.org/forums/tpi/...uble-code.html
Old Dec 2, 2009 | 01:15 AM
  #121
fltche1's Avatar
Car: 1986 Trans Am
Actually i had to replace my MAF sensor. The people who owned the car before me put it in backwards and it broke the sensor. so a note to all aspiring mechanichs... don't put your MAF sensor in backwards or it will bust and you will be out 168 dollars... it sucks... I have actually gone completely through my MAF system. Through the relays, through the wiring... all of it... my code 33 is not due to the MAF system however i will do another check to make sure the relay is activating... and i will keep you posted on the EGR problem as well... personally i think it is one of two things left for me... either a bad IAC or a problem with the ECM please please please don't let it be the ecm!!!
Old Dec 2, 2009 | 05:29 AM
  #122
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Have you cleaned the TB and IAC ; then reset them?
If the IAC passages are blocked with carbon can give bas idle
http://www.corvetteactioncenter.com/...and+Idle+Speed
Old Dec 3, 2009 | 02:08 PM
  #123
If its the ECM, then dont . For my 86 IROC-Z, It cost only like $75 at Kragen. ANd it's a refurbished or remanufactured. Go on the ORielly website (Kragen) and look for your ECM there. It shocked me to find that the "BRAIN" is cheaper than the MAF Sensor.
Old Dec 3, 2009 | 03:48 PM
  #124
fltche1's Avatar
Car: 1986 Trans Am
you can't be serious... the ecm is cheaper than the MAF sensor?!?!?! Thats is outrageous! And they are still selling the ecms? that is unbeleivable.
Old Dec 4, 2009 | 02:39 AM
  #125
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
i bought my car with the Maf backwards. it was the same either way, i used to think having the maf backwards made more power but i had to do with the weather change. the maf melted a bit on the tranny lines, replaced since, one screen only through. I heard this guy that got a camaro would rather wait over two weeks for a ecm, than buy a reman. ecm for cheaper. I despise MAF!!! 200 dollars, its just a wire. geez makes me bugged. but theyre worth it
Old Dec 4, 2009 | 01:22 PM
  #126
IrocTheZ28's Avatar
Car: '92 Z28
Engine: 350 TPI L98
Axle/Gears: 10 Bolt / 3.23
For some reason I cannot contact these guys for the availability of the EGR Temp Harness p/n: 170402077653. Ebay tells me to Ask The Seller and I get the runaround from the links Ebay provides because I'm not currently in an open transaction with them. Drives me >
My original ceramic base is cracked but the wire that feeds into it still is intact and spins around as you twist the wire, I'm not sure if its any good
but here is a pic. You tell me whether I need one or not and how I can get one. I might as well replace the EGR as well since its 21 yrs old.
Old Dec 4, 2009 | 03:49 PM
  #127
I would buy a new one. Your already going through the trouble of removing the plenum.
Old Dec 6, 2009 | 04:27 AM
  #128
burnout88's Avatar
Car: 88 IROC
Here is the current link to the one they are selling now. They have been raising the price almost every week. I paid 28 bucks and now they are up to $50.
http://cgi.ebay.com/ebaymotors/Exhau...%3D5%26ps%3D63
Can find it under there current auctions by searching under the sellers name of autopartsauction and exhaust temp sensor.
Old Dec 6, 2009 | 09:41 AM
  #129
Curious_George's Avatar
Car: '87 IROC, '92 & 99 Corvette Vert.
Engine: L98, LT1, LS1
Transmission: L98 = 700R4
Axle/Gears: L98 = 3.23 G92
I bought one (EGR temp switch) at Carquest a year ago. I am traveling, so I can't post the part number. When I get home I can post the number if everyone is still interested. The part was $18 at the time.
CG
Old Dec 6, 2009 | 10:02 AM
  #130
IrocTheZ28's Avatar
Car: '92 Z28
Engine: 350 TPI L98
F paying $50! These guys know we need them parts asap wtf...
Show me the $18 part when you get a chance, I'll be ready.
Old Dec 6, 2009 | 06:03 PM
  #131
Ok, I am in Asia and will be home around December 17th. I'll post the Carquest part number then.
CG
Old Dec 6, 2009 | 08:31 PM
  #132
Here in California, at my Carquest, they looked up the part for me and they told me that it is no longer available. This was back in the summer. Still let us know the part number so that I can give them just that.
Old Dec 6, 2009 | 10:14 PM
  #133
burnout88's Avatar
Car: 88 IROC
CG
Carquest discontinued them around Feb/March. 2009 the part # will not help. We have checked all this months ago. Ebay is the only source for the part right now and they know it. If you don't to pay 50.00 just bid lower on it and they will probably accept it.
Old Dec 6, 2009 | 11:57 PM
  #134
Has anyone tried my good friends method on post # 53?
Old Dec 7, 2009 | 04:07 AM
  #135
Originally Posted by Chevy8588
ok here is a diagram of how this bypass swicth will work, BY THE WAY, it dawned on me that this may be a good way to bypass EGR all together WITHOUT having a new prom burnt to "turn it off" unfortuneatly i have an issue with testing this out on my motor.... its not in the car lol, but if there is anyone willing to test this out it would be awesome to see my idea come to life :P
Another vacuum operated electrical switch https://www.phatperformanceparts.com...DSVOESSWITCHES
for those of you who are more technical out there and even those who are not i also included a diagram of how my bypass system stacks up next to the temp sensor, remember the temp sensor is NOT a sensor, its a switch!
I am thinking of an electronic circuit to replace the mechanical switch... a thermistor, op-amp, a few resistors, etc.
CG
Old Dec 7, 2009 | 09:04 PM
  #136
CG
. Too advanced for me. So how does it work? Is it work the time to build? And will it keep up with the abusive enviroments of an engine compartment? How about a diagram?
Old Dec 7, 2009 | 10:47 PM
  #137
IROCmenace's Avatar
Car: 1988 IROC
Chevy8588
Just wanted to thank you for all the info you put into this post. Now I am having EGR issues and failed emissions today with high HC's (267, 220 allowed) I have a new temp sensor to put in, but I need to test my solenoid with the info you supplied. Thanks again. Maybe now that global warming has been thrown out as a conspiracy, emissions testing will be the next joke confirmed not to do much.
Old Dec 7, 2009 | 11:32 PM
  #138
Chevy8588
Do you mean as in that global warming is fake, or that global warming is a growing threat?
Old Dec 8, 2009 | 09:13 AM
  #139
An op-amp has two inputs, + and - (non-inverting and inverting), which makes it easy to use as a "switch". If you place a stable reference voltage (5 volts) on one of the inputs (+ or -), this sets your reference level. A thermistor is a resistor that changes its value depending on temperature. If you place the thermistor on the "other" op-amp terminal, you now have an electronic thermal switch. I just have to fine tune a few resistor values to have the thermistor sense when the EGR valve opens and heats up the manifold. The tricky part is to figure out how to mount the thermistor into the threaded part of the EGR valve.
I am traveling right now, but give me a few days to draw up a sample circuit.
CG
Old Dec 8, 2009 | 11:59 AM
  #140
IROCmenace's Avatar
Car: 1988 IROC
Thrown out as fake. I never beleived in it. Recent news shows that scientists withheld info, lied, cheated, and tricked people into believing it was true. Gore is a butt munch.
Old Dec 8, 2009 | 06:09 PM
  #141
This thread is being hijacked. To close this non-related topic, all that Ill say is sea levels are rising due to carbon dioxide deposits into the atmosphere thus causing warmer air being absorbed into the air. Earth has its range of temperature that never drops below -100 and never passes 150 degrees on a natural givin day. Early 1900 pictures from glaciers in the artic show ice in between mountain ranges, now at the very same spot, there are deep empty valleys that were once filled with ice. Pictures show proof. Explaining and voicing theories without showing hard proof such as slide shows or actual time line pictures is just that. Time will tell if global warming is true. One thing is for sure, Tom Brokaw doesnt get paid to fool the public or give false information. That would ruin his reputation. For Tom to narrate a topic such as global warming, we all know for a fact that he approved of the scientific studies and info. so that he wont look like a fool when the cameras are recording. I strongly believe that global warming is occuring, its just hard to verify because time is the way to prove and unfortunately, time is slow. Way too slow for our generation (life span). Sorry fellaz. I had to throw in my .
Old Dec 8, 2009 | 06:13 PM
  #142
IROCmenace's Avatar
Car: 1988 IROC
To each their own. anyway Thanks again Chevy8588
Old Dec 10, 2009 | 04:15 PM
  #143
burnout88's Avatar
Car: 88 IROC
I figured out why the EGR soleniod connector is different on some cars. The 85 & 86 TPI cars use the tube style connecter (green color below)and 87 to 92 use's the caddy style connector (blue one shown below). So guys if you have an 87 to 92 TPI car the EGR soleniod for a 1995 cadillac deville with the 4.9l should plug right in. 85 and 86you will have to get a connector for an 87 to 92 car.
Attached Thumbnails EGR temp sensor has been discontinued-tpi-egr-solenoid-pigtail   EGR temp sensor has been discontinued-tpi-egr-solenoid-pigtail
Old Dec 18, 2009 | 06:43 PM
  #144
The Carquest part number is: (ECC) 72-4652 EGR Switch. The "ECC" may or may not be part of the actual part number, but it is on the box proceeding the number.
CG
Old Dec 23, 2009 | 06:35 PM
  #145
IROCmenace's Avatar
Car: 1988 IROC
For cars with older plugs for the solenoid, the 350 Truck solenoid from 87 may work. My Dad has one so I will swap it out, test it and report sometime after the holidays
Old Dec 23, 2009 | 07:12 PM
  #146
Twin_Turbo's Avatar
left is a weatherpack, right is a metri pack
Old Dec 23, 2009 | 10:38 PM
  #147
IROCmenace's Avatar
Car: 1988 IROC
my 88 has the old one.
Old Dec 23, 2009 | 11:34 PM
  #148
Chevy8588's Avatar
it seems like the plugs were characteristic between TBI and TPI, my 88 TBI had the Metri-pack, and my 87 style TPI setup has the Weather-pack.
Old Dec 24, 2009 | 06:36 AM
  #149
Well if you really believe global warming is a threat (and it sounds like you do), then do your part by selling your third gen to reduce emissions. No sense in being a hypocrite.
Whenever a volcano erupts, it spews forth thousands of times more ozone depleting "stuff", than we do, in the same given time period. Granted they only erupt occasionally. How about this... China and India's middle class is just up and coming. The amount of cars being sold in China is staggering, not to mention the pollutants from all the factories there. India is next as far as growing car sales. Their emission standards there are a joke. Unless EVERYBODY (that means everybody in the world) does something to reduce emissions, nothing good will ever come of it.
Perhaps we could commit mass genocide, as a species, to save the Earth?
I am going to keep driving my third gen and two Corvettes until they are unable to be driven. I guess if I live long enough, there might be legislation passed that bans internal combustion vehicles and then they might be forcibly taken away from me.
CG
Old Dec 24, 2009 | 02:05 PM
  #150
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
I was wondering if my logic is flawed, but following my logic, the egr solenoid is basically a TVS, the egr solenoid works via an electric signal, and the TVS works by coolant temp. Both are just a fancy way of providing vacuum at a given time. If an egr solenoid has an inlet, an outlet , and a way to remove the vacuum created via its functioning, ie a vacuum relief port. Wouldn't any egr solenoid work, following my logic, albeit it may not mount correctly, however it would still function correctly?
Therefore, if my logic is correct, when Chevy8588 installed his Camaro one in the Cadillac, and it worked, my logic is proven. In reality you could get one from any year Camaro or Corvette, or Cadillac, and as long as you had the proper connector, your good to go!!!
I'll bet that the "General" still sells the ones for the Corvette, and the Cadillac, and all you need to do is fab up a fancy bracket, and it'll look just like it came from the factory!!!
