A.I.R. pump removal
Old Jul 29, 2009 | 04:33 AM
jtlockwood88's Avatar
Car: 88 Formula 350 / 87 Iroc 68k miles
Engine: 355 / 355
Transmission: 700r4 / 700r4
Axle/Gears: 10bolt w/3.23 - 9bolt w/3.27
A.I.R. pump removal
hey guys im looking at taking of my air pump and all the stuff that goes with it. i was wondering what all would need and have done to it. also how exactly would i do it.
Old Jul 29, 2009 | 09:10 AM
thunder85's Avatar
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
Re: A.I.R. pump removal
I've done it.. if you aren't replacing the stock manifolds the biggest pita is cutting and sealing up the holes that all the tubes go to. i basically left about an inch of tube sticking up and crushed/rolled it down to seal it off until i threw headers on. you also want to plug the line into your catalytic converter. the pump comes off easy, the selenoids and rubber lines come off easy.. the only thing that i couldn't remove was the line that runs behind the engine as i couldn't get a wrench onto one of the bolts that hold it in place. i can't remember (its been some time) but i think i had to get a little bit shorter belt... hopefully someone else can pipe in on that one.
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
backtothe80s
Sep 5, 2015 12:39 AM
NBrehm
Aug 25, 2015 11:49 PM
3rdgenparts
Aug 8, 2015 07:09 PM
