Car won't take gas past 1500 rpm
Old Jul 24, 2009 | 03:44 PM
RocknRoll87's Avatar
I have a 1987 trans am 305 tpi. It will run fine until I hit around 1500 rpm and it quits taking gas. If I keep my foot in it it just spudders and dies and it takes it while before it will start again. It idles fine it just seems like it's not getting enough gas or something. I changed the fuel filter and it didn't help at all. Any ideas?
Old Jul 28, 2009 | 08:23 PM
curacaoz28's Avatar
Car: 1985 Iroc-z28(sold) 1994 camaro z28
Engine: 350lt1
Transmission: 6-speed manual
Axle/Gears: ???
Re: Car won't take gas past 1500 rpm
it souds like a elektrical problem did u check your coil. when you idle in park or nuetral does it go past 1500 rpm? if you have some good jackstands, block the fronw wheels with block or something good, raise the back put it in gear and see if it does the same.
Old Jul 28, 2009 | 08:52 PM
Bigboy23455's Avatar
Check the little hose that connects to the fuel pump in the tank.
Mine acted the same way and I found a split in that little hose.
Hope you find you problem.
Old Jul 29, 2009 | 09:22 AM
thunder85's Avatar
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
first thing i would do is pickup a fuel pressure gauge. that would be the quickest way to determine if you fp is dying on you. if you maintain fuel pressure but car dies anyway, then you can focus on electrical or spark related failure
http://www.summitracing.com/parts/ACC-74745/
thats the one i picked up.. works great.
Armored91Camaro
Aug 12, 2015 09:41 AM
ZsTransAm
Aug 11, 2015 07:30 PM
Sherpajames
Aug 7, 2015 06:56 PM
kyle5647
Aug 7, 2015 03:08 PM
