89 Trans Am
Old Jul 29, 2009 | 07:48 PM
817bigtex's Avatar
Car: 1993 Mustang,1989 GTA
Engine: 5.0 302,5.7 350
Transmission: AOD Built 500HP Mustang
Axle/Gears: 8.8 Rear Built 4.10's Mustang
89 Trans Am
How much hp can the stock block handle if I run 8psi? Its a auto Trans am, will the trany and rear end handle the 8spi aswell?
Old Jul 30, 2009 | 12:36 AM
thunder85's Avatar
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
Re: 89 Trans Am
8psi is about the max you should run on a stock bottom end. from what i'm told, a stock bottom end can hold about 500 horse before you start running the risk of popping it. also depends on the mileage (rings worn, etc).
Old Jul 31, 2009 | 12:04 PM
817bigtex's Avatar
Re: 89 Trans Am
How much Hp you think I can make if I run 6psi?
1992 Trans Am
May 10, 2023 07:19 PM
Hawk312
Aug 22, 2017 08:55 PM
Hello, Michael
Aug 20, 2015 03:19 PM
mizz0313
Aug 12, 2015 06:45 AM
Leggman1
Aug 6, 2015 04:15 AM
