HELP!!!!!!!
Old Aug 5, 2009 | 06:16 PM
charlietransam's Avatar
Car: 1984 Trans am
Engine: V8
HELP!!!!!!!
i have a 84 trans am and the fuel gauge stays at full all the time. what can be the problem. a friend told me i can use my two fingers and gently put pressure on the fuel gauge and it will give me an estimate of how much fuel i have in my tank. is that true? and what can be the cause of the problem and how can i fix it.
Old Aug 5, 2009 | 06:47 PM
renemedrano842's Avatar
Car: 92 GTA
Transmission: 5 Speed
Axle/Gears: 3.27 posi
Re: HELP!!!!!!!
your sending unit in the gas tank probably went out, gonna have to drop the tank to fix it
Old Aug 5, 2009 | 07:09 PM
ParkerTPIz's Avatar
Re: HELP!!!!!!!
yep sounds like the sending unit. dropping the tank is the right way...but if u want a quicker fix cut the cheater hole. its not the proper way but we've all done it at some point.
