not getting fuel
Old Jul 31, 2009 | 11:48 PM
soxbaseball's Avatar
not getting fuel
I just got my 87 trans am gta with a 5.0 about a week ago now. when i bought the car it didnt run the guy told me that he parked it about a month ago and it ran fine then. So i thought it would be the fuel pump because i couldn't hear it priming when i turned the switch. So i replaced it and the fuel sending unit. Once I got the old fuel pump out I tested it and it was good. What would keep the pump from running? I thought maybe a relay but I dont know where they are and i dont know how I would test it if I did know where it was!
Old Aug 1, 2009 | 12:48 AM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Re: not getting fuel
check the ecm fuse by the battery and see if you are getting spark could be the spark control module
Old Aug 1, 2009 | 11:20 PM
im getting spark because the car will run with ether. when i turn the key no dash lights come on i dont think this is normal. what would cause this to happend????
Old Aug 2, 2009 | 12:34 AM
quickkris2006's Avatar
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
find the power wire for the fuel pump behind the rear seat under the carpet and see if its getting power.
Old Aug 2, 2009 | 11:16 PM
the only way it getspower is if i send power to it though the bottom left pin in the obd plug and its getting plenty of pressure to the fuel rail when i do that its just the injectors arnt getting signal to release fuel into in cylinder
Old Aug 4, 2009 | 12:42 AM
MTXaudioSYSTM's Avatar
Car: 90 formula
Transmission: auto
hmm.
Old Aug 4, 2009 | 10:13 PM
I changed the ecm today and nothing changed
Old Aug 5, 2009 | 02:40 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
on the positive battery cable, there is a red wire follow it untill you find a fuseholder with a 20 amp fuse in it, replace that fuse and you should be good to go.
this fuse controls the ecm and fuel pump. No idiot lights on is the tip off.
Old Aug 5, 2009 | 06:00 PM
I did that what about that fusible link that runs to it
Old Aug 5, 2009 | 07:44 PM
Hold a finger on a fuel injector while a buddy cranks the motor, you should be able to feel the injector clicking. If not, replace your ignition module as it also controls the fuel injector pulse.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
mike_c
Aug 27, 2015 04:32 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
