TPI INTAKE
Old Aug 7, 2009 | 07:53 PM
92WS6 T/A's Avatar
Car: 1992 WS6 T/A
Engine: Turbo 383 with Holley Sniper
Transmission: factory 5 speed now Powerglide
Axle/Gears: Strange 12 bolt w/373 locker
TPI INTAKE
I've got a 92 trans am with a 305 TPI, has 170000 miles. while driving down the highway, a rod stated knocking. i have a 1969 or 70 350 block, will my my tpi setup bolt right up to my 350?
Old Aug 8, 2009 | 05:29 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: TPI INTAKE
Yes.
But you'll have to oval some of the holes in the intake manifold to make it bolt to the heads on your old 350 block.
Old Aug 10, 2009 | 01:06 AM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
Re: TPI INTAKE
They will fit fine if you use the heads that are in the car now.
Old Aug 10, 2009 | 01:58 AM
92WS6 T/A's Avatar
Car: 1992 WS6 T/A
Re: TPI INTAKE
thanks guys, this will help ALOT!!!! now i've just gotta put it in.
Old Aug 10, 2009 | 03:34 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: TPI INTAKE
Yeah I would definitely switch to a set of 083 heads... But he has the 081s... which may or may not be a good compression range for a 350... but the stock tune isnt gonna work with a 350 anyway.
But yeah, the TPI will bolt up aside from a few intake bolts that are a different angle. I'd consider doing a head swap on that 350 to a set of 083 (TPI Iron L98 heads) heads and trying to find a stock 350 ECM. You'll need a new knock sensor also, and I think there's one other thing you need...
But your TPI system is Speed Density, so you dont have a MAF to help with a tune mismatch. But if you go with stock parts, the tune from a 350 should work.
1992rs/ss
Jan 31, 2025 05:10 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
masonta
Aug 31, 2015 10:14 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
